99 Yukon Random Misfire - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-17-2013, 04:43 AM   #1
So just re did the top end and adjusted the valves twice, still getting codes for random misfire on cyl 6, repaved the injectors and started getting this problem has new plugs, wires abd cap n rotor and I'm stumped as to wat could be causing this problem any ideas would be appreciated
zach1926284 is offline   Reply With Quote
Old 11-17-2013, 05:29 AM   #2
Cracked porcelain on spark plug. Many yrs (1992) ago I had a 85 t bird w/ a 302v8. I changed plugs myself. Car would miss at low speeds. Dealer charged me $500( new egr valve etc) to fix. Still missed. Turned out to be a hairline crack on spark plug.
toolaholic is offline   Reply With Quote
Old 11-17-2013, 06:59 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
...pull the fuel pump relay....
Crank the engine over for about 30 seconds..
Pull the plug....look at #6....does it have any moisture on it? If so...leaky head gasket.
Old 12-05-2013, 08:07 AM   #4
Did you use OEM AC Delco parts?
Hardway is offline   Reply With Quote
Old 12-05-2013, 11:54 AM   #5
Used felpro higher end gaskets, ac Delco plugs, ended up being one of the new injectors not sitting correctly and corrected itself, drove it last night after my wife had been driving for a few days and no longer misses at any rpm so that's honestly the only thing I can think of that could've been the problem, New design doesn't have the oem clips from 99, it was changed by gm in 00 or 01 according to service notes from gm global connect
Old 12-05-2013, 11:03 PM   #6
ukrkoz's Avatar
Rewards Points: 938
You can adjust valves on Yukon V8-s? Don't they have hydraulic lifters?
ukrkoz is offline   Reply With Quote
Old 12-09-2013, 06:39 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
+1
That is a bit scary to start with.
Old 12-09-2013, 06:48 PM   #8
Not the lifters as its not a consistent misfire
Old 12-09-2013, 08:54 PM   #9
ukrkoz's Avatar
Rewards Points: 938
Zach, you missed my question. I have never heard of valve adjustments on GM V8s for those years, as they have hydraulic lifters. I was curious, how did you adjust the valves then. Your OP said so.
Old 12-10-2013, 07:41 AM   #10
That was my point as well. Most GM Rocker assemblies are just bolt down until snug these days or spin the pushrod until you feel drag and 1/4 - 1/2 turn beyond there.
First Co. 36RCW5-HP blower stopping at random times cout HVAC 2 07-06-2011 05:51 PM
Random Orbital Sander Suggestions (<$100) hyunelan2 Tools 11 03-28-2011 08:49 AM
Outdoor post light - random blinking bulb handymike Electrical 9 06-14-2010 02:29 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
Ridgid Random Orbit Sander jamiedolan Tools 2 03-17-2009 03:23 AM
