99 Silverado Oil Sending Unit - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-17-2008, 02:17 PM   #1
Question
99 silverado oil sending unit
I need to know where the oil sending unit is located. My manuel doesn't have anything on that topic. Anyone have an idea?
TeamGio is offline   Reply With Quote
Old 09-24-2008, 11:35 AM   #2
oil pan
It should be on the oil pan.
sssalas is offline   Reply With Quote
Old 10-25-2008, 09:09 PM   #3
re silverado oil pressure sending unit
the oil temp. sensor is on the left side of the oil pan, the oil level sensor is on the right side of the oil pan, the oil pressure sending unit is if you have a 4.3L vin "w" is on the top left rear of the engine near the distributor, if you have a 6.5L vin "f" or"s" it is located under the intake manifold on the left side of the engine
dnto303@yahoo.com is offline   Reply With Quote
Old 02-10-2009, 06:49 PM   #4
First of all a 99 silverado cannot have a 6.5 diesel it it.
The oil pressure sending unit is at the rear of the intake manifold mounted into a fitting going into the engine block. The low oil level sensor is in the oil pan.
oregondiy is offline   Reply With Quote
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 08:51 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
Ouside Unit on. Inside Fan off mycuss HVAC 5 08-04-2008 08:01 PM
