-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   99 silverado oil sending unit (http://www.diychatroom.com/f46/99-silverado-oil-sending-unit-25336/)
TeamGio 08-17-2008 02:17 PM
I need to know where the oil sending unit is located. My manuel doesn't have anything on that topic. Anyone have an idea?
sssalas 09-24-2008 11:35 AM
oil pan
It should be on the oil pan.
dnto303@yahoo.com 10-25-2008 09:09 PM
re silverado oil pressure sending unit
the oil temp. sensor is on the left side of the oil pan, the oil level sensor is on the right side of the oil pan, the oil pressure sending unit is if you have a 4.3L vin "w" is on the top left rear of the engine near the distributor, if you have a 6.5L vin "f" or"s" it is located under the intake manifold on the left side of the engine
http://www.ondemand5.com/mric/common...63&PRINT_BW=0& http://www.ondemand5.com/mric/common...63&PRINT_BW=0&
oregondiy 02-10-2009 06:49 PM
First of all a 99 silverado cannot have a 6.5 diesel it it.
The oil pressure sending unit is at the rear of the intake manifold mounted into a fitting going into the engine block. The low oil level sensor is in the oil pan.
