99 Ford Expedition - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-06-2013, 04:30 AM   #1
Rewards Points: 164
99 ford expedition
Have this SUV starts up first thing in the morning no problem, when driving it then shut it off? It has a long delay on starting, what is this I am afraid starter will go, it's almost like it needs priming?? Help
bostonwindows30 is offline   Reply With Quote
Old 12-06-2013, 07:34 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... What motor is in it,..??
What have ya done to find the problem,..??
Bondo is online now   Reply With Quote
Old 12-06-2013, 07:37 AM   #3
Rewards Points: 164
V8 triton 5.4 motor I think it might be the crank shaft sensor????? I don't know??
Old 12-06-2013, 02:09 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Are you getting any trouble codes?
Mort is offline   Reply With Quote
Old 12-06-2013, 02:16 PM   #5
Rewards Points: 164
No codes
Old 12-06-2013, 02:17 PM   #6
Rewards Points: 164
Crank censor?
Old 12-06-2013, 05:49 PM   #7
Mort's Avatar
Rewards Points: 690
Its hard to recommend replacing it if you aren't getting a code. Does the starter act like its struggling, or is it cranking at a good speed but not firing?
Old 12-06-2013, 05:57 PM   #8
Rewards Points: 164
No struggle just takes double the time to turn over
Old 12-07-2013, 01:04 PM   #9
Oso954's Avatar
Rewards Points: 752
When was the last time you changed the fuel filter ?
Oso954 is online now   Reply With Quote
Old 12-07-2013, 01:53 PM   #10
ukrkoz's Avatar
Rewards Points: 934
1. Air leak somewhere. Metal expands from heat, gaps open, and mixture turns lean, preventing start up.
2. Just the opposite. Leaking injector. Floods hot engine causing no start.
No telling from this side. You need to pull plugs out and investigate for signs of lean or flooded burn. Which, in my opinion, you need to check your plugs one way or another.
Failing coolant temp sensor is known but well forgotten culprit to starting issues.
http://autorepair.about.com/cs/troub...042603a_02.htm
http://www.underhoodservice.com/Arti...omplaints.aspx
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
Windows on Wash (12-09-2013)
David is a Ford Guy now??? Bluwolf Off Topic 16 06-16-2013 09:54 PM
Ford Motor Company Posts Doc Holliday Off Topic 32 04-11-2013 03:24 AM
check suspension light 2000 expedition OpieGoneBad Automotive Repairs 1 01-03-2013 08:13 PM
Ford Expidition and F250 Door lock problem danrb007 Automotive Repairs 5 04-05-2011 08:35 PM
1997 ford expedition remote sgtrock Automotive Repairs 13 02-10-2009 08:53 AM
