99 Dodge 1500 Won't Idle - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-17-2012, 06:50 AM   #1
Rewards Points: 582
99 dodge 1500 won't idle
changed starter in truck....everything was fine for a day...battery went dead son said he left overhead lite on...jumped truck started ok leave off gas dies...start it up rev engine everything seems ok leave off gas dies...any help
Old 07-17-2012, 09:55 AM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I had an old Camaro where, after you disconnected the battery or it died, you'd have to drive it around for a few minutes above 35mph to get the computer to reset. It wouldn't idle at all before it did that.
Mort is online now   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
ben's plumbing (07-17-2012)
Old 07-17-2012, 11:52 AM   #3
Rewards Points: 106
My first thought would be a vacuum leak. Obviously start with the areas where you were working, to see if you may have inadvertently dislodged a line or something, but, otherwise, and although coincidental if that were the case, intake manifold leaks are not all that uncommon.
The Following User Says Thank You to DexterII For This Useful Post:
Old 07-17-2012, 06:30 PM   #4
Rewards Points: 582
up date....took battery to advanced auto to have checked...they said it was to low needed charged.....they charged it and said battery was good....reinstalled in truck...everything is working fine
Old 07-17-2012, 06:33 PM   #5
DIY staff
Rewards Points: 7,174
Good--computer would have reset after battery had recharged----If you have further trouble--see my PM---
ben's plumbing (07-18-2012)
Old 07-18-2012, 09:38 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
At idle, most alternators are only supply just enough to keep the battery topped off and electrical powered.
Not uncommon for the ignition to draw from the battery at idle.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 07-18-2012, 09:59 PM   #7
A Little Of Everything
Rewards Points: 1,364
The ECM needs to readjust itself. You should be fine, given several more frustrating days of it dying at idle.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
ben's plumbing (07-20-2012)
Old 07-20-2012, 09:19 AM   #8
TWX
Rewards Points: 35
That computer reacts to that significantly more quickly than that. Worst case the vehicle wouldn't shift as timely as the driver expects and might lack a little power.
I agree that it's most likely that the ignition wasn't getting enough power at idle to keep the truck running.
It could also be a sign of a weak alternator, so bear that in mind.
TWX is offline   Reply With Quote
The Following User Says Thank You to TWX For This Useful Post:
Old 07-20-2012, 09:23 AM   #9
Right. It certainly SHOULDN'T take it anywhere near that long to adjust.
Old 07-24-2012, 08:01 PM   #10
oldgoat82's Avatar
My 97 used to do the same thing when the batt voltage dropped. The ECM loses part of the code And the truck will run poorly. Disconnect the batt for at least 15 mins to allow all capacitors to discharge. Reconnect and jump to start or start with a new batt if needed. Then you gotta for a ride so that the ECM re-learn all engine parameters. Good luck.
oldgoat82 is offline   Reply With Quote
2005 Dodge Ram 1500 Brake Job Aggie67 Automotive Repairs 32 04-25-2012 05:50 PM
New Brakes for Dodge Ram 1500 4x4 Track Dad Automotive Repairs 7 03-27-2011 08:37 PM
Brake job 2005 Dodge Ram 4x4 1500 Grizzley Automotive Repairs 1 10-28-2010 04:47 PM
Rough Lawnmower idle. Please advise. Shaun_in_NC Landscaping & Lawn Care 2 01-01-2009 04:44 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 07:48 AM
