99 Chevy Astro Van Blower Motor Acustic Cover Clips. - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-11-2013, 11:32 PM   #1
99 Chevy Astro van blower motor Acustic cover clips.
Anybody know where I can get the clips to put the acustic cover back on after blower motor replacement?
Hardway is offline   Reply With Quote
Old 03-12-2013, 09:43 AM   #2
Rewards Points: 14,306
Junk yard.
ltd (03-12-2013)
Old 03-12-2013, 01:49 PM   #3
Stealership, if they even understand what you are talking about.
paintdrying is offline   Reply With Quote
Old 03-12-2013, 01:55 PM   #4
Originally Posted by joecaption View Post
Junk yard.
Not Junk yard item!
Old 03-12-2013, 01:57 PM   #5
It will be my last resort, it takes 5. The "Stealership" will want $5.00 each need 5.
Old 03-12-2013, 02:06 PM   #6
Per the "Stealership" the clips are not offered other then in an AC Delco blower motor kit, $160.00.
So it is improvise time.
Old 03-12-2013, 02:29 PM   #7
so typical. My blower is out in my astro as well. 160 bucks for a blower kit. LOL. Let me know what you come up with
Old 03-12-2013, 02:48 PM   #8
I have the blower motor $30.00.
This is the Acustic cover cut out, it was easy to cut with a carton knife.
There is corasponding tabs on the other part still on the van. A Youtube video say to discard the Acustic cover.
I will put it back some how, there is one screw that holds it on.
The clips were not on there, cost cutting I am sure!
On the right, the printing says to cut between the lines!
Old 03-15-2013, 01:44 PM   #9
Put the the new blower in and working good. As for the clips, I line up both tabs and used a hot nail to make holes, and used small zip ties to hold it in place. I bent a nail on a 45, held it with vise grips and heated it with propane torch.
Took 1.5 hours, can be done in an hour after knowing what to do!
Old 03-16-2013, 10:01 AM   #10
ukrkoz's Avatar
Rewards Points: 990
My man!! That's why it's called DIY forum, not running to dealership and forking for plastic clips. Next time maybe short self tapping screws?
ukrkoz is offline   Reply With Quote
Old 03-16-2013, 09:16 PM   #11
r0ckstarr's Avatar
Rewards Points: 2,064
Nice job on improvising and ingenuity!
r0ckstarr is offline   Reply With Quote
Old 05-07-2013, 01:01 PM   #12
Plastic little brittle screw would crack, it not enough room to use plastic pop rivet.
Polaris Water Heater Blower TMcCrea HVAC 0 06-10-2012 06:17 AM
furnace blower cover whistling BlueBSH HVAC 4 02-17-2011 03:09 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
