99 Chevy Astro Van - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-04-2012, 01:53 AM   #16
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by Hardway
The Astro is not drivable, but I have a second vehicle. The Astro is what I need a tool for. I don't ever rent any tools, buy only. However changing a shaft seal in the parking lot is not possible. Also there is city ordnance, no working on cars in the parking lot. Now minor repairs, they will let ya slide. If I had to pay to have the Astro repaired it would have to go. I have good set of tools, as good as most repair centers. Just don’t have everything, as the vehicles change.
I wasn't saying to work on it there other than to see if you are getting the right Allen wrench.
Then go home, fix it and return the wrench for your deposit back.
Why buy a tool you'll never need again?
But hey...your money your way.
titanoman is offline   Reply With Quote
Old 02-04-2012, 03:04 AM   #17
Busy DIYer
picflight's Avatar
Rewards Points: 150
DrHicks, good idea to rent tools, I did not know that. I need a brake bleeder so I can replace my brake fluid.
picflight is offline   Reply With Quote
Old 02-04-2012, 03:20 AM   #18
Not sure why you need to change brake fluid, but you donít need anything other then a 2í length of small rubber house that will fit snug on too the bleeder screw. Take a plastic spring cloth pin. Zip tie the cloth pin to the rubber hose, so that when you clip the hose on pint jar, the hose is about half inch from the bottom of the jar. Pour clean brake fluid in the bottom of the jar, so the hose is sitting in the fluid. Put the other end of the hose onto the bleeder screw. Place a dab of grease around the hose and bleeder. Open the bleeder screw and gravity will take care of the rest. Make sure you keep topping the master cylinder off. For bleeding brake start at the wheel furthest from the master cylinder.
Hardway is offline   Reply With Quote
1992 chevy disc brakes Bristles Automotive Repairs 6 10-23-2011 03:59 PM
1993 chevy tbi gasket leak HEVYD13 Automotive Repairs 1 03-31-2011 08:41 PM
93 chevy 1500 problems Coreystultz Automotive Repairs 6 10-08-2010 06:50 AM
94 chevy 4x4 truck problem tecate1987 Automotive Repairs 45 11-15-2009 01:24 PM
Chevy vs ? RegeSullivan Off Topic 0 11-06-2009 05:08 PM
