99 Chevy Astro Van - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-03-2012, 04:52 PM   #1
99 Chevy Astro Van
99 Chevy Astro Van
Anybody know what size allen (hex) bit that fits the center shaft on the power steering pump shaft. Also what size wrench is the pulley? Need to replace shaft seal.
Hardway is offline   Reply With Quote
Old 02-03-2012, 06:26 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Park in front of o'reilly's and borrow whatever fits. They rent tools for free.
titanoman is offline   Reply With Quote
Old 02-03-2012, 06:59 PM   #3
A Little Of Everything
Rewards Points: 1,364
I don't want to presume to tell you what to do here, but why pay almost $20 for a seal when you could buy a complete re-manufactured pump for $40?
DrHicks is offline   Reply With Quote
Old 02-03-2012, 11:06 PM   #4
Thanks for the advise, but I am not paying $20.00 for the seal but rather $2.00.
I already have everything apart, as I replaced the water pump and hoses.
Easy enough to replace seal, at this time. However when I get back at it in the morning, I may change my mind and replace the pump. I do have the seal on hand, donít have right size allen wrench.
Old 02-03-2012, 11:09 PM   #5
Now this is really good advise, not
Old 02-03-2012, 11:29 PM   #6
Disabled wood vet
titanoman's Avatar
Well, if your pride cometh before...whatever they say...then replace the pump like the other dude said.
Old 02-03-2012, 11:32 PM   #7
Explain this statement as it makes no sense!
Old 02-03-2012, 11:38 PM   #8
Cool. I was just going by what I found on the OReilly site, that indicated the seal was $16.99.
Old 02-03-2012, 11:46 PM   #9
Why the snarky comment? I rent tools from OReily's quite often.
Old 02-03-2012, 11:48 PM   #10
Disabled wood vet
titanoman's Avatar
I was wondering why renting the tools you need is a farfetched idea?
Weren't you suggesting you needed to acquire a wrench if you knew what size it was?
But it sounds like your vehicle isn't driveable right now, so nix that anyway.
Is that why my suggestion was not a good one?
Edit: Thank-you, DrHicks.
Old 02-03-2012, 11:49 PM   #11
I ordered a sway bar online so I threw a seal in, just did not get around to installing it.
Old 02-04-2012, 01:02 AM   #12
Ahhh... Apparently didn't get it from OReily's. $16.99 does seem oddly expensive for a seal that is that small.
Old 02-04-2012, 01:15 AM   #13
nope anything i can wait on, i order online. even with shipping cheaper then OReily'y.
Old 02-04-2012, 01:25 AM   #14
The Astro is not drivable, but I have a second vehicle. The Astro is what I need a tool for. I don't ever rent any tools, buy only. However changing a shaft seal in the parking lot is not possible. Also there is city ordnance, no working on cars in the parking lot. Now minor repairs, they will let ya slide. If I had to pay to have the Astro repaired it would have to go. I have good set of tools, as good as most repair centers. Just donít have everything, as the vehicles change.
Old 02-04-2012, 01:43 AM   #15
The Astro is not drivable, but I have a second vehicle. The Astro is what I need a tool for. I don't ever rent any tools, buy only. However changing a shaft seal in the parking lot is not possible. Also there is city ordnance, no working on cars in the parking lot. Now minor repairs, they will let ya slide. If I had to pay to have the Astro repaired it would have to go. I have good set of tools, as good as most repair centers. Just don’t have everything, as the vehicles change.
I've found myself renting tools more frequently. The way OReily's does it, it's more like borrowing them. When I return the tool, they refund the rental charge.
I recently rented an axle nut socket, to use on my Grand Cherokee. Dumb thing would have cost about $35 to buy, and being a 36mm socket, it's unlikely I'd ever use it for anything else. So "borrowing" it was pretty sweet.
Other things I've "borrowed" from OReily's recently include...
Code Scanner
Coil spring compressors
Ball joint separator
Brake-line bender
Brake-line flanger
Pulley puller
My decision is based on the cost of buying the tool, and the likelihood of needing to use it again.
1992 chevy disc brakes Bristles Automotive Repairs 6 10-23-2011 03:59 PM
1993 chevy tbi gasket leak HEVYD13 Automotive Repairs 1 03-31-2011 08:41 PM
93 chevy 1500 problems Coreystultz Automotive Repairs 6 10-08-2010 06:50 AM
94 chevy 4x4 truck problem tecate1987 Automotive Repairs 45 11-15-2009 01:24 PM
Chevy vs ? RegeSullivan Off Topic 0 11-06-2009 05:08 PM
