99 Chevy Astro Misfire Runs Rough Code P0301 - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-29-2013, 11:20 PM   #31
cocobolo's Avatar
Rewards Points: 5,952
Something else I just thought of. You can get some sort of cleaner for your fuel injection, which you just introduce into the intake system somehow. It has been years since I did that, but it helped. Might be worth a try. Mine was a 4.3 as well.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-08-2013, 11:39 PM   #32
Update as I stated all summer no check engine light. I was up north for ten days, it got down to 48 degrees and I got a check engine light. I drove 50 miles back to the property and parked it. On the way home I hit 68 degrees about a 100 miles from the property and the check engine light went off and stayed off 250 miles home.
I will scan it in the morning and post the code.
Hardway is offline   Reply With Quote
Old 10-09-2013, 10:11 AM   #33
P0301 misfire number one cylinder!
Old 10-09-2013, 10:14 AM   #34
Rewards Points: 254
Good chance it's the injector sticking. They are very common to get carboned up and stick more so cold.
cjm94 is offline   Reply With Quote
The Following User Says Thank You to cjm94 For This Useful Post:
Hardway (10-09-2013)
Old 10-09-2013, 01:15 PM   #35
I just hate to pull the top and replace the spider assembly and have the same problem. I ran a few cans of GM heavy duty fuel injector cleaner thru it. Did not improve it though. I have looked into purchasing the equipment to inject thru the fuel rail. I will call around and see who does the injector cleaner and cost?
Old 10-09-2013, 01:23 PM   #36
Rewards Points: 254
Don't expect to much on the flush it's not a guarantee. In almost 20 years of working on cars I'm at probably 40% of flushing injectors fixing anything
Old 10-09-2013, 10:45 PM   #37
I pretty much concur on the flushing.
I don't have a garage and this is my main ride.
I like working on cars, just don't like to be rushed.
It being van with engine cover makes it a little more involved.
Not going to take it in anymore, they charge too much and mess something else up. Like when they replace the fuel pump and dropped the tank without disconnecting the filler neck. Damaged the OEM cap and trim around the fill neck. "Oh we did not do that because we did not disconnect it" "All we did was lower the tank." really?
I will keep ya updated from time to time!
Old 10-29-2013, 10:35 AM   #38
Did you manage to fix it?
Just wondering whether putting some Super Unleaded is going to help the car. After all, they got some of the injector cleaning stuff, too.
davey68 is offline   Reply With Quote
Old 10-29-2013, 11:00 PM   #39
Astrovans get the hose disconnected from the neck at the tank, it won't come out otherwise. If you don't have the updated injector assembly, it's a good investment if you are keeping the van. Possible sticking valve though...if the misfire happens under load or at high speed, it's something to consider.
Lotek is offline   Reply With Quote
Old 11-17-2013, 09:57 PM   #40
Lord of Slums
Rewards Points: 1,974
I was thinking weak valve spring as well. You could try running a half quart synthetic oil on the next change. If the filler neck is leaking might trying running some Heet through it.
mj12 is offline   Reply With Quote
Old 11-27-2013, 08:16 PM   #41
Mid October, I did a full tune up my self AC Delco parts.
coil, cap, rotor,plugs, wires.
Cleared all codes and did not recieve anymore codes.
Still rough idle in drive stopped at a light.
Old 03-02-2014, 04:08 PM   #42
So far no codes!
Old 03-02-2014, 09:10 PM   #43
Rewards Points: 236
these 4.3's are not the smoothest idlers. but a clogged egr will make em idle really bad, and is a common problem.
Fix'n it is offline   Reply With Quote
Old 07-08-2014, 07:34 AM   #44
Rewards Points: 14
I had a 1998 Blazer with the 4.3, the truck had 175k, and when running it would feel like a misfire. I found the distributor gear had worn out to the point that many of the teeth had 1/16" of wear on them. I know of one other person who had this same problem. It causes your timing to shift, and can cause a misfire.
1995droptopz is offline   Reply With Quote
Old 07-08-2014, 07:45 AM   #45
socially awkward
brotherGood's Avatar
Just read the last page of it. Glad you don't have anymore codes. A rough idle could be a vacuum leak, clogged injector..something like that.. I wouldnt think itd be a worn distributor gear unless you were having the stumble all the time. Have you replaced your fuel filter?
Also, double check your plugs. I'm betting they'll show a lean condition, but I'm not good with fuel injection..So I could be wrong
brotherGood is offline   Reply With Quote
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
99 Chevy Astro Van Hardway Automotive Repairs 17 02-04-2012 02:20 AM
Code for low voltage runs through PVC in attic camel Electrical 1 07-09-2011 03:38 PM
Bryant Plus 80 Code 33 fan runs all time! ideas? westomaha HVAC 1 12-25-2008 11:09 AM
Since my mower ran out of gas....runs rough checkin2 Landscaping & Lawn Care 3 07-24-2008 12:46 PM
