99 Chevy Astro Misfire Runs Rough Code P0301 - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-28-2012, 07:11 PM   #16
Injectors
Ok thanks for all the info, I will research replacing the injectors before I start. I will take pix so if I forget where something goes. It is just a matter of starting the process.
Hardway is offline   Reply With Quote
Old 12-14-2012, 12:36 AM   #17
Update, done nothing so far. But now it is running so smoothe, can't tell it is running idling at a red light. Check eng light has not came back on yet. So I don't know.
Old 01-19-2013, 08:20 AM   #18
Dude, do not get into that spider system. On an astro it is able to be done but is very tight. You should take it in for a fuel injection cleaning, you have a poppet stuck. If the dealer did not use ac delco parts than pull all those off. Also replace the wires. I can not stress enough that you need to use ac delco parts on that van.
paintdrying is offline   Reply With Quote
Old 01-19-2013, 04:20 PM   #19
Rewards Points: 268
I had one of them in our shop awhile back for a misfire that would come and go (P0307 - Cyl 7 Misfire). The owner had it another shop and they replaced a ton of parts. All that was left was the injector spider. I have worked on so many Chevy 4.3/5.0/5.7's that I have boxes of spare parts. I threw on a distributor cap that I knew was good and that took care of the intermittent misfire. It had been replaced already. And it was an ACDelco part. Those caps were a terrible design to begin with (they cross conductor paths in the cap so that the wires come neatly off each side). Maybe a defect in the cap, maybe the guy who put it in dropped it, maybe the box got dropped during shipping, etc, it doesn't take much.
In my experience once the spider poppets plug up they don't usually come back on their own. I've had 50/50 luck using a high pressure injector cleaning tool. But replacing the spider assembly isn't very difficult. I'd use the new design if at all possible...much better design (no poppets).
I had a 99 Astro AWD for 2 years. It was awesome in the snow, I'll say that. And I'm not a Chevy guy. But finally sold it off as the gas mileage was rotten and the wife wanted a sliding door on both sides (we had just had twins).
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
toolaholic (01-19-2013)
Old 01-19-2013, 04:41 PM   #20
Have not had the P0301 code or any code since my last post. I agree with you that a plugged injector is not going clear up and the reappear. I also have read several articles on the after market caps. Still runs rough at idle thou. Who sells Delco caps?
Old 01-19-2013, 09:14 PM   #21
Rock auto is my favorite for parts. Those 4.3 can run rough on idle. Might be your egr valve. Or that air control valve is dirty. I do not even worry about miss fires anymore. Astros run bad longer than most cars run
Old 01-19-2013, 09:30 PM   #22
Thumbs down
Yeah I looked at Rockauto, buy a lot from them. Even with the shiping, $20.00 less then local patrs store. I will order cap and. rotor and go from there. EGR tested good! When you say air control valve meaning Mass air flow it was replaced. It has been in the shop a few times and they replaced a bunch of stuff. I gave up on them, "just bring it back" got old!
Old 01-19-2013, 09:55 PM   #23
Air idle control valve. You can clean this w/ throttle body cleaner.
toolaholic is offline   Reply With Quote
Old 02-01-2013, 01:26 PM   #24
Up date:
I have not done anything because of cold weather. I let the gas run down to less then an 1/8 of a tank and filled the tank. On the way home from the gas station the check engine light came on. I drove it a short distance and back home check eng light still on. Next day I started it and the check eng light was off. I am driving it; still rough idle at the stop light. I did not check to see what code is stored as of yet. I will get around to changing cap and rotor with OEM Delco. 15 degrees at the moment, I will post when I do something. I thought I would just update!
Old 02-02-2013, 12:06 AM   #25
Never below a quarter of a tank of gas, you will burn that pump up fast. I tested this theory on an astro I had and burned the pump up in less than a week.
Old 02-02-2013, 01:58 PM   #26
I don't doubt what you say, I used to run close to out of gas all the time. The OEM pump lasted 13 years 120,000 miles. Just saying
Old 06-05-2013, 01:56 AM   #27
Update:
I never got around to doing anything.
The check eng light reset and has not came back on. So I don't know what it can be. I will update if it changes.
Old 09-14-2013, 11:13 AM   #28
Never did do anything other then basic maintenance and the check engine light has not came back on. Still idles rough stopped at the light. The dealers never figured out the rough idle they would test drive it with me and tell me they donít notice it. Needless to say the dealers is no longer in business. So just updating.
Old 09-22-2013, 07:24 PM   #29
cocobolo's Avatar
Rewards Points: 5,952
ALL Chevy 6's and 8's really love a good ignition. If there's something wrong with your distributor cap, rotor, plug wires, plugs etc., it could very well cause the trouble you are having. Having read your whole thread, I would lean toward an electrical problem, all of which is easy to fix.
Have you pulled the valve covers to see if any of the rocker arms are slightly loose? Occasionally a cam lobe will start to go flat and cause trouble, but not any too often.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 09-28-2013, 11:30 PM   #30
distributor cap, rotor, plug wires, plugs etc, all new.
No have not checked the rocker arms.
In the past a lose rocker would chatter. I put a vacume gauge on it and no flutter.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
99 Chevy Astro Van Hardway Automotive Repairs 17 02-04-2012 02:20 AM
Code for low voltage runs through PVC in attic camel Electrical 1 07-09-2011 03:38 PM
Bryant Plus 80 Code 33 fan runs all time! ideas? westomaha HVAC 1 12-25-2008 11:09 AM
Since my mower ran out of gas....runs rough checkin2 Landscaping & Lawn Care 3 07-24-2008 12:46 PM
