99 Blazer Help - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-06-2013, 12:59 PM   #31
Haverhill Trade 1965
Originally Posted by bostonwindows30 View Post
Just found out, no compression on 5 and 6 I am thinking the valves went, bad news need another engine...,.
How did you determine the two cylinders had no compression? Seldom would there be NO compression without something like a hole in the piston or cylinder wall. A proper compression test is done with, charged battery, all plugs removed, throttle open, and same number of compression strokes, usually 3 or 4, dry then wet, (second try with a squirt of oil in each cylinder), Bad rings would show an increase pressure with the oil. Another test is put compressed air into each cylinder @tdc and listen for air at intake, exhaust, oil filler, and radiator. It will isolate a problem with rings, valves, or head gasket, if blown into water jacket or oil passage.
Duckweather is offline   Reply With Quote
Old 08-06-2013, 04:32 PM   #32
Rewards Points: 164
So you think the valves are not running because of that??
bostonwindows30 is offline   Reply With Quote
Old 08-06-2013, 05:48 PM   #33
Rewards Points: 164
I took to a mechanic
Old 08-06-2013, 05:59 PM   #34
I cannot tell without being there. What I gave you is the orderly troublshooting procedure that will pinpoint or eliminate which component is the cause of compression loss. There may be other problems but you must eliminate this one if it is suspect. Nothing else will work properly without compression. Was a good compression gauge used to determine this?
Blazer ac problem bostonwindows30 Automotive Repairs 8 07-02-2013 06:02 PM
Ac on blazer bostonwindows30 Automotive Repairs 6 06-30-2013 06:38 PM
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 11:21 AM
90 chevy blazer darney Automotive Repairs 4 07-23-2009 10:34 PM
2004 S10 Blazer gas tank joeyuk Automotive Repairs 5 06-13-2008 09:41 AM
