99 Blazer Help - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-03-2013, 03:58 PM   #16
Rewards Points: 164
Nope nothing worked even changed out some lines, changed PVC valve and plugs are good, don't know now!!!
bostonwindows30 is offline   Reply With Quote
Old 08-03-2013, 05:06 PM   #17
Still Decompressing
Rewards Points: 273
Does your car have the 4.3L v6?
I am sure you would have stated this.....
Are there any 'check engine' or 'service' codes showing up? Are you getting good fuel pressure?
Have you given the intake / throttle body a good cleaning lately? It could be something with the fuel injectors getting clogged.
I dealt with an EFI saturn that had a bad idle mixture. It was causing a very high idle but that may be worth checking. I think it was called a IACV on the saturns (GM product) (longshot)
I know a compression test is not easy for most DIYers, but that will let you know if you are getting good compression on all cylinders.
caveeagle is offline   Reply With Quote
Old 08-05-2013, 04:10 PM   #18
Rewards Points: 164
Just found out, no compression on 5 and 6 I am thinking the valves went, bad news need another engine...,.
Old 08-05-2013, 04:34 PM   #19
Bigplanz's Avatar
Rewards Points: 996
Check whether fuel is getting to the dead cylinders.
Bigplanz is offline   Reply With Quote
Old 08-05-2013, 06:10 PM   #20
Haverhill Trade 1965
Could be a blown head gasket. can you see if there is a lot of sludge built up inside valve covers? Sometimes the pushrods can get so gummed they can't move fast enough and get bounced off the rocker arms. FYI from my Army training a fuel system has only five "circuits", high, low, pump, float, choke. Even all the new sensors control one of these circuits. They are all controlled within the computer instead of individually, but if you know how each sensor is linked, you can narrow down a problem.
Duckweather is offline   Reply With Quote
Old 08-05-2013, 06:17 PM   #21
Rewards Points: 254
Check fuel psi to see if it holds psi. The regulator is under the upper intake and are common to leak and flood out the back cylinders. The rings may just be washed out from gas. Compression will usually come back if you put a little oil down the plug hole after you fix the fuel leak.
cjm94 is offline   Reply With Quote
Old 08-05-2013, 06:28 PM   #22
Rewards Points: 164
I don't see no fuel leak
Old 08-05-2013, 06:29 PM   #23
Rewards Points: 164
Just put regular oil down in the hole???
Old 08-05-2013, 08:03 PM   #24
Rewards Points: 254
It will be an internal leak you won't be able to see it. That's why you need a fuel psi gauge and see if it holds psi. And yes regular oil you don't need much. Put a little down the plug hole and the crank it over before installing the plug.
Old 08-05-2013, 08:06 PM   #25
Rewards Points: 164
Okay will do thanks..
Old 08-05-2013, 09:13 PM   #26
Still Decompressing
Rewards Points: 273
I don't think you confirmed engine type. If you have the 4.3L v6, GM had a serious issue with their 98-2000 Fuel injection systems. It was like a "spider" system that actual dripped fuel into the intake runners. They were chronically bad and GM even offered a retro-fit kit to correct the problem.
Not sure if this is your problem, but your symtoms sound a lot like the issue I had with my 2000 Express van that had the 4.3L v6.
Old 08-06-2013, 02:49 AM   #27
Rewards Points: 164
Yes it is the same engine, so what should I do??
Old 08-06-2013, 05:54 AM   #28
Rewards Points: 254
Star with testing fuel psi
Old 08-06-2013, 08:07 AM   #29
Still Decompressing
Rewards Points: 273
Checking the Fuel PSI is a good start. Also start reading up on GM's Pre 2000 fuel injection issue. I paid a shop to repair the 4.3 that was in my full size van, but yours should be much easier to work on in a blazer.
I memory is correct, NAPA sold the kit, but it was a bit pricey. ($350 range, from memory). This was a common problem. Check to make sure your car was not already upgraded by a prior owner (probably not). If your on a tight budget, you might even try searching the junk yards for 97-00 GMs with the same 4.3. Many cars were retro-fitted by GM under warranty, and you might just find what you need, and get it dirt cheap. **you have to know what your looking for**
I will try to post a link if I can find it.
Here is a good link with some information and pics of the conversion. They sell the conversion, but it seems a bit pricey to me. Check around on the net. Rock Auto, NAPA etc. (make sure this is your problem before shelling out the $$)
http://www.theautoshop.net/VortecMPFI.htm
Old 08-06-2013, 08:32 AM   #30
Still Decompressing
Rewards Points: 273
Here is another site with better pictures and a better price for the upgrade kit. (FYI)
http://www.fuelinjector.citymaker.co...onversion.html
Blazer ac problem bostonwindows30 Automotive Repairs 8 07-02-2013 06:02 PM
Ac on blazer bostonwindows30 Automotive Repairs 6 06-30-2013 06:38 PM
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 11:21 AM
90 chevy blazer darney Automotive Repairs 4 07-23-2009 10:34 PM
2004 S10 Blazer gas tank joeyuk Automotive Repairs 5 06-13-2008 09:41 AM
