99 ASTRO Expansion Plugs Location - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-24-2012, 08:52 PM   #1
Tileguy
Bud Cline's Avatar
Rewards Points: 558
99 Astro 4.3...
How many freeze plugs are there in the (block) and where are they?
THX
Old 06-25-2012, 06:14 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
They should be under the exhaust manifolds, on the front of the block (not sure about under the timing cover), and on the back of the block behind the bell housing. All various sizes, of course.
Mort is online now   Reply With Quote
Old 06-25-2012, 06:51 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 998
Ayuh,.... There's a couple on each side of the block, 'n 2 behind the flywheel....
1, 5/8" I think...
Bondo is online now   Reply With Quote
Old 06-25-2012, 10:34 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks guys, wasn't sure where to look. Had two push out last winter, just now getting around to investigating and making the repairs. I suppose once the two are replaced and water is added, if any more are gone I'll know it then and know where to find them.
Old 06-26-2012, 10:14 AM   #5
Mort's Avatar
Rewards Points: 692
Oy. I hope that's what it takes, but I've been around the auto industry for 15 years, and I've never heard of those things working like they're supposed to. If they pop out, the block is most likely cracked. I hope I'm wrong, but hope for the best and plan for the worst.
Old 06-26-2012, 01:59 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That is certainly a possibility. The system developed a leak last fall somewhere on the topside. I didn't use the vehicle that much at the time and didn't want or need the repair cost back then. So I would add water every few days, eventually diluting the coolant/anti-freeze presence. Then the vehicle sat all winter and recently when I added water it of course gushed from the missing expansion plugs.
I wouldn't be surprised if the block was cracked but it is worth treating it as if it was not until I can prove otherwise. I can't see the wisdom in putting the vehicle in a shop and having the repairs done only to find the block is cracked, so we will proceed as far as we can without creating another costly shop-charge.
Old 06-26-2012, 08:58 PM   #7
Rewards Points: 236
your topside leak is probably the intake gaskets. common problem on those engines. the updated gaskets are a lot better.
if the block is cracked, you very well may get by with some "good" sealer.
Fix'n it is offline   Reply With Quote
Old 06-26-2012, 09:07 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Your topside leak is probably the intake gaskets. common problem on those engines. the updated gaskets are a lot better. If the block is cracked, you very well may get by with some "good" sealer.
"Good sealer" such as........?
Now a motor mount has to be temporarily removed to access one of the freeze-plugs. That's a pain ALSO!
Old 07-14-2012, 10:04 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,996
Something like this: http://bluemagicusa.com/index.php/bl...c/category/25/
If the crack is hairline, you will be okay. Most freeze cracks I have seen do more damage than first noted and you will be putting a new motor in the car most of the time.
Do a coolant pressure test and see where the leak is first.
The let you borrow the tester at the parts stores.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
expansion tank location Rankid Plumbing 3 10-21-2011 10:33 PM
cutting plugs off would violate... Daneel Electrical 9 06-05-2011 04:21 AM
Location of expansion tank? speedster1 Plumbing 8 12-21-2010 03:50 AM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 09:01 AM
