'98 Mitsubishi Galant - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-22-2008, 10:36 PM   #1
I have a '98 Mitsubishi Galant, yesterday when I started it up it started making a clicking sound, today i found out if I set it to recirculate air the sound goes away. The clicking slows down when there is higher draw on the battery. Any ideas what making this noise, and how to stop it?
Sliver is offline   Reply With Quote
Old 12-23-2008, 02:01 PM   #2
Oldguy
Rehabber's Avatar
Probably a foreign object has fallen into the air ducts and is touching the blower fan. NEVER put any objects on the dashboard as they tend to drop into the defrost ducts and work their way to the blower.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-23-2008, 09:41 PM   #3
I've never had anything up on the dash. Is there usually a separate fan for fresh air intake and one for just circulating air?
Old 12-23-2008, 11:06 PM   #4
Oldguy
Rehabber's Avatar
Just one fan, the blend of air is done with moving a door. Pull the blower motor and see what is in there.
Old 12-26-2008, 05:21 PM   #5
What happens if you turn the ac/blower fan off... Does the clicking go away?
nperkins is offline   Reply With Quote
Old 12-26-2008, 08:09 PM   #6
No, the clicking only goes away if its recirculating air.
The clicking isn't affected by fan speed or which vents it comes out, and only clicks with fresh air.
Old 12-26-2008, 08:12 PM   #7
So if its on fresh air but the fan is off it still clicks? Does it change by engine RPM or vehicle speed? What about if the key is on but the engine isnt running?
