98 Ford Explorer Differential Oil Refill - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-27-2008, 06:04 PM   #1
Res Ipsa Loquitur
Hello all,
I am trying to locate where to refill the rear diff on my son's 98 Explorer Sport. I pulled the cover, drained out the old fluid, cleaned, gasketed and reapplied the cover. When I went to refill the fluid I was dumbfounded to not find where it gets replenished. It is a 4 wd, 2 door model. All I could see was a small bolt, (13mm) on top of the diff and also a sensor of some sort.
Any Explorer people out there?
Thanks!
Update- fill plug it had been rusted over and wasn't visible. Fluid now changed!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-01-2008, 11:10 AM   #2
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Is this the 8.8"? The fill plug should be near the pinion yoke, on the driver side if I remember correctly. It should be a plug you can fit a 3/8" ratchet extension into, but could have changed. The sensor is for the ABS - don't mess with it. Don't forget to add friction modifier - yours is most likely limited slip and they get noisey without the additive. I had some tag #'s and diagrams somewhere...
Try this:
http://www.therangerstation.com/tech_library/Axles.html
EDIT: Ooops, too late.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 02-03-2008, 09:21 AM   #3
Res Ipsa Loquitur
Thank you- I found it-
Is the friction modifier a product obtained from retail stores like Auto Zone or Pep Boys or is it only a dealer available addin?
Old 02-03-2008, 09:38 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
As far as I know, it's a dealer thing
But you'll need to find out if you need it
testdummy is correct the Ford limited slip dif needs it
But I don't know if you've got it or not
slickshift is offline   Reply With Quote
Old 02-05-2008, 08:24 AM   #5
Fixer-'til-broker
Rewards Points: 262
Autozone carries it. Comes in a squeeze tube. If it's not on the shelf with the gear oil ask for it at the counter.
Old 02-06-2008, 07:20 AM   #6
Res Ipsa Loquitur
Thanks!
Old 02-06-2008, 12:32 PM   #7
everything and anything you want to know about your son's explorer can be found at explorerforum.com. Its a great board with lots of explorer fans. I used to be on it alot when I had my '91 explorer.
as DIY said it should be up by the pinion yoke
have2goski is offline   Reply With Quote
Old 02-06-2008, 06:01 PM   #8
Res Ipsa Loquitur
Thanks- I got it from Advance Auto Parts on the shelf near the engine supplements- it was $5.00 for the tube by CRC Industries.
Old 02-07-2008, 08:47 AM   #9
Fixer-'til-broker
Rewards Points: 262
I'm a Jeep man, but I have an 8.8" ready to install. There has been a running joke for many years from explorerforum.com about a guy who got Herculiner on his "hootus." I will say no more to keep it "PG" rated.
Old 02-07-2008, 06:13 PM   #10
i know the story
Old 09-10-2009, 10:07 PM   #11
Hos much to use?
How much of the tube do you use? I have refilled the diff with Lucas 80w90 but I read on the tube not to over use? I also have a 98 explorer sport 4X4. Any suggestions?
Thanks,
Russel
RussBoogie is offline   Reply With Quote
Old 09-15-2009, 11:26 AM   #12
Fixer-'til-broker
Rewards Points: 262
Russ,
Do you know if you have a limited-slip differential? If it's an open carrier, you don't need friction modifier. If it is LSD, read the tube and/or your owner's manual, but I always used to put the whole tube in. I know most Ford 8.8" axles are open carriers with C-clips. Suprisingly, even most of the towing packages don't include limited-slip.
