-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   98 Ford Explorer Differential Oil Refill (http://www.diychatroom.com/f46/98-ford-explorer-differential-oil-refill-16235/)
handyman78 01-27-2008 07:04 PM
Hello all,
I am trying to locate where to refill the rear diff on my son's 98 Explorer Sport. I pulled the cover, drained out the old fluid, cleaned, gasketed and reapplied the cover. When I went to refill the fluid I was dumbfounded to not find where it gets replenished. It is a 4 wd, 2 door model. All I could see was a small bolt, (13mm) on top of the diff and also a sensor of some sort.
Any Explorer people out there?
Thanks!
Update- fill plug it had been rusted over and wasn't visible. Fluid now changed!
DIYtestdummy 02-01-2008 12:10 PM
Is this the 8.8"? The fill plug should be near the pinion yoke, on the driver side if I remember correctly. It should be a plug you can fit a 3/8" ratchet extension into, but could have changed. The sensor is for the ABS - don't mess with it. Don't forget to add friction modifier - yours is most likely limited slip and they get noisey without the additive. I had some tag #'s and diagrams somewhere...
Try this:
http://www.therangerstation.com/tech_library/Axles.html
EDIT: Ooops, too late.
handyman78 02-03-2008 10:21 AM
Thank you- I found it-
Is the friction modifier a product obtained from retail stores like Auto Zone or Pep Boys or is it only a dealer available addin?
slickshift 02-03-2008 10:38 AM
As far as I know, it's a dealer thing
But you'll need to find out if you need it
testdummy is correct the Ford limited slip dif needs it
But I don't know if you've got it or not
DIYtestdummy 02-05-2008 09:24 AM
Autozone carries it. Comes in a squeeze tube. If it's not on the shelf with the gear oil ask for it at the counter.
handyman78 02-06-2008 08:20 AM
Thanks!
have2goski 02-06-2008 01:32 PM
everything and anything you want to know about your son's explorer can be found at explorerforum.com. Its a great board with lots of explorer fans. I used to be on it alot when I had my '91 explorer.
as DIY said it should be up by the pinion yoke
handyman78 02-06-2008 07:01 PM
Thanks- I got it from Advance Auto Parts on the shelf near the engine supplements- it was $5.00 for the tube by CRC Industries.
:thumbsup:
DIYtestdummy 02-07-2008 09:47 AM
:thumbup:
I'm a Jeep man, but I have an 8.8" ready to install. There has been a running joke for many years from explorerforum.com about a guy who got Herculiner on his "hootus." I will say no more to keep it "PG" rated.
have2goski 02-07-2008 07:13 PM
i know the story:laughing:
RussBoogie 09-10-2009 11:07 PM
Hos much to use?
How much of the tube do you use? I have refilled the diff with Lucas 80w90 but I read on the tube not to over use? I also have a 98 explorer sport 4X4. Any suggestions?
Thanks,
Russel
DIYtestdummy 09-15-2009 12:26 PM
Russ,
Do you know if you have a limited-slip differential? If it's an open carrier, you don't need friction modifier. If it is LSD, read the tube and/or your owner's manual, but I always used to put the whole tube in. I know most Ford 8.8" axles are open carriers with C-clips. Suprisingly, even most of the towing packages don't include limited-slip.
