98 Dodge Neon Front Bumper Removal - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-10-2008, 12:31 PM   #1
Question
98 Dodge Neon front bumper removal
how do you remove the front bumper from a 4-door 98 Neon (so I can repaint it)...thanks, Drew
dsimpson is offline   Reply With Quote
Old 12-26-2008, 12:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,...
Remove all of the nuts, bolts, screws,+ any wiring.....
Then it'll come Right Off....
A Better Bet, is to just prep in on the car, tape it off,+ Shoot it....
Old 01-13-2011, 08:06 PM   #3
ukrkoz's Avatar
Rewards Points: 952
well, you have bumper itself and bumper cover, or fascia.
it is very likely that you have 2 large bolts, right behind the tire wells, holding 2 long bars, that bumper is attached to, to the chassis. when those bolts are removed, and minor screws disconnected, the bumper assembly should slide out of the guides it is sitting on.
what kind of repair you need to do? a lot can be done with bumper assembly still on the car.
also, here's a quick and dirty. any local library will have Chilton repair manual. 20 cents worth of copies will give you a good guide, right?
bumper covers are very inexpensive through Certifit. but you'll have to paint it.
ukrkoz is offline   Reply With Quote
Tags
98 neon , bumper , parts removal
