98' Dodge ?? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-17-2011, 03:02 AM   #1
98' Dodge ??
I have a 98' Dodge Ram 1500,and with the hood up,and looking at the fire wall,I can see water comming out of the pipe comming off the heater core.Does that mean that the core is gone bad?Could there be other problems other than the core?Thanks;Mack
BigMack is offline   Reply With Quote
Old 08-17-2011, 05:55 AM   #2
Rewards Points: 294
If it is antifreeze, then you have a leak. If you only use water in your cooling system is MIGHT be a leak. If you use antifreeze, and it is leaking water, and you have air conditioning, it is probably just AC condensation run off, and that is normal.
polarzak is online now   Reply With Quote
2000 Dodge Ram Roofmaster417 Automotive Repairs 4 01-31-2011 01:27 PM
91 Dodge Cummins probs-wiring 4just1don Automotive Repairs 1 12-05-2008 03:09 PM
Dodge Durango Rack and Pinion Bushing BenJoeM Automotive Repairs 1 11-29-2008 08:34 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 07:48 AM
Dodge Minivan Transmission STEPHENWANGEL Automotive Repairs 4 02-19-2007 07:14 PM
