-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   98' Dodge ?? (http://www.diychatroom.com/f46/98-dodge-114301/)
BigMack 08-17-2011 03:02 AM
98' Dodge ??
I have a 98' Dodge Ram 1500,and with the hood up,and looking at the fire wall,I can see water comming out of the pipe comming off the heater core.Does that mean that the core is gone bad?Could there be other problems other than the core?Thanks;Mack
polarzak 08-17-2011 05:55 AM
If it is antifreeze, then you have a leak. If you only use water in your cooling system is MIGHT be a leak. If you use antifreeze, and it is leaking water, and you have air conditioning, it is probably just AC condensation run off, and that is normal.
