98 Dakota Occasional Loss Of Power Then Backfire - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-07-2012, 07:00 PM   #1
98 Dakota occasional loss of power then backfire
Every once in a while I will get a sense that the acceleration is of or idle is slightly of eventually it will run rough (stumble) then back fire. After that it will be fine until next time. Giving it more gas doesn't seem the help any I've floored it and it still lost speed.
It doesn't seem to be engine temp related. Any ideas and any way to test for it?
rodm1 is offline   Reply With Quote
Old 02-07-2012, 07:14 PM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
The timing is off.
If the ignition is computer controlled, 98, probably is, looks like a faulty chip.
picflight is offline   Reply With Quote
Old 02-07-2012, 07:17 PM   #3
Rewards Points: 254
Your catalytic converter could be broken up and plugging your exhaust. Pretty common on those bang on your cat and if it rattles it's bad. You can test for back psi with a gauge in the o2 sensor port or disconnect the exhaust before the cat and drive it.
cjm94 is offline   Reply With Quote
Old 02-08-2012, 09:45 AM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
"He is talking about bangs and shimmy, doesn't look like instrumentation to me!"
If there is a rattle on idle, then you have a bad catalytic converter too.
Old 02-08-2012, 10:34 PM   #5
Rewards Points: 254
Who said anything about instrumentation?
Old 02-08-2012, 11:15 PM   #6
raise the hood at night and see if you see any sparks jumping between the plug wires. happened to me once.
Old 02-09-2012, 01:53 PM   #7
Rewards Points: 296
Does sound like a cat converter problem to me. If you can provide more info such as the mileage, last time plugs and wires were changed, etc., we can narrow down a few things.
Eagle One is offline   Reply With Quote
Old 02-10-2012, 07:35 PM   #8
Plugs and wires changed in probable the last 30,000 miles, miles on OD176,000. It wouldn't think it would be anything maintenance related. I keep up the maintenance on it.
What about the IAC valve could that be something to look at? If the cat whose plunged wouldn't the rear o2 censer light come on?
I will look into these but the exhaust might have to weight until wormer weather.
Old 02-10-2012, 10:10 PM   #9
Rewards Points: 254
The iac valve does not do anything off idle. It is used to control idle and replace the dash pot function for sudden deceleration. On older dodges the downstream O2 sensors are not real tight parameters. I actually removed the cat on my 96 for a while when it plugged and it did not set the light.
Old 02-13-2012, 11:08 AM   #10
Rewards Points: 296
Do you know if that is the original cat on there? If so, I would definitely be looking at that as the problem. 176K miles is a lot if you never had it changed.
Old 02-13-2012, 06:56 PM   #11
I believe its OEM but not positive. If it will not mess up the computer I could remove it when it worms up.
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
