97 VW Jetta Help, A Few Items - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-27-2012, 02:56 PM   #1
Rewards Points: 335
Exclamation
97 VW Jetta help, a few items
I have a 97 VW Jetta, 5 speed, 2.0 engine, gas
We purchased this car as my daughters first car and are slowly taking care of the problems. It runs and it goes like it should but now it's coming time to start repairing some of the "things". I have a few questions, if you could help me out, I'd greatly appreciate it.
1. when we start the car it runs fine, then all of a sudden, from inside the vehicle, we will hear a high pitched ringing. It's coming from somewhere on the drivers side. When we accelerate, that ringing goes away. Let off the gas, it comes back. It's very small but almost like a ringing in your ear that we sometimes get. But it doesnt go away unless accelerating.
2. There is an exhaust problem somewhere. It doesn't sound as bad as driving with no muffler but we definitely hear the bogging down noise that makes me think there is something bad with the muffler, catalytic converter, or maybe a hole some where. How do you know if the cat is bad or the muffler? Any way to test it?
3. if you are facing the front of the car, and you are looking at the passenger side front turning light...........right behind that light, towards the bottom of the front end and to the left of the radiator, there is a silver cylindrical canister sitting in the corner. What is this cylinder? and what is it for? There is a rubber hose of some sort sticking out of it that has been cut off for whatever reason. Can someone tell me what this is?
can anyone help me with these few items?
crankbait09 is offline   Reply With Quote
Old 02-28-2012, 11:12 PM   #2
ukrkoz's Avatar
Rewards Points: 930
2. take her Midas. They do not charge for inspection.
3. possibly, a part of a/c system, thugh a/c has aluminum metal tubing. metal shiny cylinder is usually condenser, if I did not confuse the names. sorry, it's dryer:
http://thetruthoflife-hazirah.blogsp...mediately.html
does a/c work?
ukrkoz is offline   Reply With Quote
Old 02-29-2012, 07:56 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
1. Loose belt?
It's not turbo-charged is it? Turbos sometimes whine at low rpm.
titanoman is offline   Reply With Quote
Old 02-29-2012, 09:13 AM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
I'm not a VW expert, but there are many out there. Check out some of the VW enthusiast forums and you'll probably have an answer within minutes, if not seconds. VWVortex is one that comes to mind.
hyunelan2 is offline   Reply With Quote
Old 03-08-2012, 09:01 AM   #5
A Little Of Everything
Rewards Points: 1,356
Is it really a ringing, or a high-pitched "whirr"? There is a little electric blower motor, between the engine and radiator, that is part of the EGR system. This is not the same blower as the electric radiator fans. It could be that that you're hearing.
This question really cannot be answered without you jacking up the car, rolling under it and examining the entire exhaust system. Over the years of driving my Golf, I replaced everything EXCEPT the cat converter.
If I remember correctly, that is part of the AC System.
I had a '97 Golf for many years. Same car, except hatchback.
I'd strongly suggest you get involved in some VW Forums. VWVortex comes to mind. The members of those forums are OBSESSED with their VWs, and will be FAR more help than we can be.
Enjoy the VW!
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
crankbait09 (03-08-2012)
Old 03-08-2012, 09:04 AM   #6
Rewards Points: 335
I have recently subscribed to the VWVortex site.............I will be posting most questions there.
Thank you
Items to Need for Things WirelessG Off Topic 5 02-18-2011 02:48 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Items are prevent door from opening...what to do? foodiechick General DIY Discussions 11 04-24-2010 11:07 AM
DIY Decorating with Goodwill items butacska Interior Decorating 5 08-20-2009 10:50 PM
Help! I need a shopping centre where i can buy most of my items depriate4repair General DIY Discussions 3 03-01-2007 10:49 PM
