97 Plymouth Grand Voyager Died - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-06-2008, 01:01 PM   #1
97 plymouth grand voyager died
Hi. My son-in-law has a 97 plymouth grand voyager 3.0 v6.it died while he was driving it and now it will not start.I was wondering if it might be either a fuel filter,fuel pump,or some type of safty switch or even a fusse .Could use help finding location of parts and problem .
jamesw6777 is offline   Reply With Quote
Old 09-06-2008, 03:03 PM   #2
Oldguy
Rehabber's Avatar
Need to test to see if it has spark first. Pull 1 plug wire, attach to a spark plug held to ground in a position where you can see the spark gap. Crank the engine and look for a blue spark.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 09-06-2008, 03:34 PM   #3
97 voyager died
The engine will turn over but it will not start.It acts like it is not getting any gas.
Old 09-06-2008, 04:15 PM   #4
Oldguy
Rehabber's Avatar
The engine requires air, spark at the plugs and fuel to start. Does it have spark at the plug?
Old 09-06-2008, 06:23 PM   #5
97 voyager died
There is no spark The wires that go into the distributer all look good but the number 3 wire,it looked all coroded and green.
Old 09-06-2008, 06:55 PM   #6
Oldguy
Rehabber's Avatar
Make sure the rotor is turning when you crank the engine. Assumung it is, the most common problem will be crank position sensor, cam position sensor or ignition control module. You will also want to replace the dist cap, rotor and wires (and spark plugs if the center electrode is rounded a little) A bad wire can contribute to ign module failure.
Old 09-06-2008, 07:04 PM   #7
97 voyager died
OK thanks .Where should I start looking for these sensors and the modual ?
Old 09-06-2008, 08:27 PM   #8
Oldguy
Rehabber's Avatar
Cam sensor will be in block between cyl heads behind power steering reservoir, crank sensor near the harmonic balancer or crank pulley, the ign module will be in the distributor.
Old 09-06-2008, 08:49 PM   #9
97 voyager died
Thanks. I will check these out and then let you know what I find.
Old 09-08-2008, 08:06 AM   #10
47_47's Avatar
Rewards Points: 44
Was the timing belt ever changed? If it is original, go to Autozone and rent a compression gauge.
47_47 is offline   Reply With Quote
Old 09-09-2008, 01:54 PM   #11
97 voyager died
I believe the timing belt has never been changed . How do you use a compression guage and what will it mean ?
Old 09-09-2008, 04:03 PM   #12
Oldguy
Rehabber's Avatar
He is refering to the possibility of a broken timing belt. Thats why I referred to ' assuming the rotor is turning' If the rotor in the distributor is turning, you do not have a broken timing belt. thus no need to do a compression test.
Old 09-24-2008, 12:10 PM   #13
Simple Checks
Keep in mind that most vehicles that are no starts are constantly being cranked, and by that action, the battery can get weak. Before any testing make sure the battery is fully charged.
Check all fuses with a test light, they're usually in a plasic box under the hood. When in doubt of relays; Mark with chalk Position before swaping, swap relay with same part number of relay that operate other functions. Never swap out a relay that has a differant part number on it. Alawys note position.
If as you later describe that one plug wire was "green" I'd replace them all and replace spark plugs while Im at it. When checking for spark make sure that your using insulated plyers to hold the plug wire with the plug in it, Id say about a little less than 1/2 inch from engine ground, then have someone crank engine.
If you still don't have spark, check with a test light if you have power coming into the coil pack, if you do, then I'd replace the coil pack.
Fuel pressure check: under the hood there will be three plastic screw on types of plugs on metal tubing; the red and blue are AC DON'T REMOVE THOSE! Look for a smaller black one on the fuel rail, unscrew it, with key on, compresspress the tinny medal thing, if fuel squirts out very fast, then your fuel pump has pressure, if it dribbles out then there is a problem with the fuel pump. Fuel pump is in the fuel tank.
sssalas is offline   Reply With Quote
Old 10-24-2008, 04:25 PM   #14
97 grand voyager died
my son in law finally checked the timing belt and discovered that it was broke.He replaced it and it works now. Thanks.He also told me that when the car is in reverse the blower motor stops working but will start again when back in drive.Any ideas?
Old 10-27-2008, 02:59 PM   #15
47_47's Avatar
Rewards Points: 44
I'd check for properly routed wiring harnesses. It may be the rocking of the engine in reverse is opening a connection or stressing a weak wire.
Compressor died, can it be replaced DIY? Firecracker HVAC 11 09-01-2008 09:41 PM
stratus died REBILL Automotive Repairs 4 12-17-2007 01:18 PM
