97 Olds Shiloutte Air Shocks Running On - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-30-2012, 08:30 PM   #1
Rewards Points: 562
97 olds shiloutte air shocks running on
My 97 olds shilouette air pump is running an awful lot and today didnt shut off.
What needs fixed? the shocks? How much do those cost? or the pump? Its the load balancer for the rear of the car if you have passengers in the rumble seat.
4just1don is offline   Reply With Quote
Old 01-30-2012, 10:37 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Cool.
titanoman is offline   Reply With Quote
Old 01-31-2012, 06:17 AM   #3
Rewards Points: 274
I love these things. Have had them in all my recent cars. In my 69 GTO they were manual. (you had to go to the garage and pump them up like a tire)
Never had any problems, so I am taking a stab here. The sensor could be shot, and thinking the car is not level, is telling the pump to pump. You could have a leak in the lines or in the shocks themselves. If the pump is running, I would not suspect it.
polarzak is offline   Reply With Quote
Old 01-31-2012, 08:07 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... It's hard to say, but I'd guess you have an air leak somewhere...
It could be Anywhere between the pump, 'n the shocks, or at the pump, or at the shocks...
The ONLY way to know is crawl under it, 'n Look/ Listen...
Old 02-01-2012, 05:29 AM   #5
Rewards Points: 562
ok, I crawl under and see this box controlled by wand on suspension,,,where this wand is position wise determines how fast it 'leaks' down.
Now weird thing shocks are very rusty where they join. One creeps up and down slpwly,,,the other one ,more slowly yet
Recently it rides like a lumber wagon on every little bump,,,and makes terrible clunking sounds.
air pump used to run a few seconds and quit,,,now it runs for many minutes and still doesnt raise much.
where do I begin to fix? this cant last long like this
Old 02-01-2012, 06:16 AM   #6
Rewards Points: 274
Use the old soapy solution trick. Get some dish soap and water and spray it on the lines and shocks. Bubbles should be seen where the leak is. Replace the defective component.
Based on the clunking thoough, I would suspect the shock
Old 02-01-2012, 07:45 AM   #7
Bondo's Avatar
Rewards Points: 628
Ayuh,... That's the height control valve....
Push the lever down, the car is supposed to go Up...
Push the lever up, 'n the air bleeds off, 'n the car goes down....
You've got a Leak,...
Find, 'n fix the Leak...
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 05:00 AM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 10:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
