97 Jetta Car Alarm - Please Help - Can't Start - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-31-2012, 10:42 PM   #1
Rewards Points: 335
97 Jetta car alarm - please help - can't start
I have a 97 Jetta and for some reason, everytime I try and start the car, the alarm sounds. I have unhooked the negative battery cable in hopes of resetting the alarm, which does not fix it.
I have shut all doors and tried starting it, but no luck.....alarm sounds and I have to stick the key in the trunk to turn it off.
I don't understand why it's going off. I can open the doors fine and get in to the trunk, but as soon as i try and start it.....the alarm goes off.
I have pulled fuses hoping they would control the alarm, but still no luck.
What is causing this?
crankbait09 is offline   Reply With Quote
Old 01-31-2012, 11:26 PM   #2
Door contact switch bad ?
Carkid0007 is offline   Reply With Quote
Old 02-01-2012, 10:10 AM   #3
If it is a factory alarm, read the owner's manual.
If that does not work, you would need the factory service manual set of books which would include an electrical diagrams manual. And understand how to read electrical diagrams.
Or take it to a dealer.
If 3rd party alarm, then read instructions for that. Or contact that manufacturer.
Billy_Bob is offline   Reply With Quote
Old 02-13-2012, 08:30 PM   #4
Usually a vw will do this when the battery is dead or weak, charge it or replace it and you should be good to go. Good luck
Cas95 is offline   Reply With Quote
Old 02-13-2012, 09:33 PM   #5
bbo
I have an aftermarket alarm on a vehicle I have thats in storage during the winter. Does the same thing if I leave the batt in and don't charge it.
bbo is offline   Reply With Quote
Old 02-13-2012, 10:34 PM   #6
A Little Of Everything
Rewards Points: 1,364
I had a '97 Golf, and had the same problem with a slightly different cause. This is a very problematic flaw in that vintage VWs.
It will do you no good to read the owner's manual. It won't do you much more to take it to a dealer.
In order to reset the alarm, you need to disconnect the negative battery cable, and leave it disconnected for several minutes. This, however, does not solve your problem.
The "brain box" for that security system is inside the dashboard, directly in front of the headlight switch. It has been enough years ago that I've forgotten exactly what to do, but there is a way that you can bypass the thing. I'd suggest you go on VWVortex, or some other VW forums, for more detailed instructions. They'll know what to tell you.
Good luck!
DrHicks is offline   Reply With Quote
Old 02-23-2012, 09:30 PM   #7
Rewards Points: 335
It was odd, I disconnected the alarm module from under the dash and let it rest for a few minutes. I plugged it back in and all was done. Car started right up. Maybe just needed reset???? Not sure, but it runs good.
compressor wants to start but won't wetbar HVAC 13 06-17-2010 07:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 02:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
