97 Grand Marquis.thump, Every 10 Second Or So??????????? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-03-2010, 06:56 PM   #1
bsa_bob
Rewards Points: 150
97 grand marquis.thump, every 10 second or so???????????
I have a thump and it slows the engine just a bit when it clunks, A young fella told me it sounded like a power surge.This being caused by a low freon charge.And the car is an automatic teemperature control. he believed the the A/C compressor was short cycling.
Does this ring true with any of you.
bsa_bob is offline   Reply With Quote
Old 11-03-2010, 06:58 PM   #2
Rewards Points: 502
does it do it if you unplug the compressor clutch?
forresth is offline   Reply With Quote
Old 11-03-2010, 07:00 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, very familiar.
any idea what an AC compressor looks like? Even if not, since it is doing this, you should be able to see it as it cycles so,
open the hood, start the engine and watch (NO NOT TOUCH) the front of the engine. If it is the AC compressor, you should be able to see one of the pulleys go around, then stop, then spin again, and on and on. A lot of them tend to make a kind of rattle sound when they are spinning.
If that is it, yes, you are low on refrigerant and would need at least a recharge. You have a leak somewhere.
Old 11-03-2010, 07:03 PM   #4
bsa_bob
Rewards Points: 150
Unhappy
occasional anti-freeze smell 97 marquis
This car after it sets a month or two will give off a strong smell of anti-freeze when you start it up-------after a day or two on the road, it [smell] leaves the car. Nothing on the floor, nothing showing leakage on the motor,or hoses.And its not low when the oil is changed. nothing on the w/s to make me think its a leaking heater core.
Man those are expensive , and the whole dash comes down. i saw some pictures of the job. like i say i can't smell anything now.
Old 11-03-2010, 07:05 PM   #5
bsa_bob
Rewards Points: 150
If i just use the heat on manual.......no thump.
Old 11-03-2010, 07:09 PM   #6
bsa_bob
Rewards Points: 150
two posts entwined here very sorry all.
This fella said i should not put to much freon in it with out the gauges,.i could lock the compressor up! I have added freon since the 70s.and haven't locked one up yet. Is this a true staement.cause i don't know any help appreciated greatly bob s
Old 11-03-2010, 07:21 PM   #7
nap
You talking to me?
nap's Avatar
you can destroy a compressor by adding freon improperly or overcharging.
but,,with that, I rarely use gauges myself.
Old 11-03-2010, 09:29 PM   #8
bsa_bob
Rewards Points: 150
thanks for the help all!
Old 11-12-2010, 07:15 AM   #9
Rewards Points: 150
Disconnect the mag coil on the. Compressor and drive. Or you could just turn of climate control. Could have a bad body control module. The pulley will always spin. As far a 'slugging the compressor'. It depends on the type of compressor. Recip in auto can be dammged. Scroll and screws good luck trying to break those.
ianc435 is offline   Reply With Quote
