-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   '97 f150 tranny growl (http://www.diychatroom.com/f46/97-f150-tranny-growl-70106/)
boman47k 04-28-2010 06:55 PM
Seems to growl and vibrate when changing gears sometimes. Converter?
I don't have the truck with me right now, but it seems to do it more when going into overdrive or high. Sometimes it almost feels/sounds like running over those wake-up strips on the side of the road for a second or two.
4.6 auto 4x
cowboy dan 04-30-2010 09:19 PM
4.6 auto 4x
how does it drive? usually when a tranny goes. it slips in or out or both. a converter would rattle because the shaft is dammaged, u wouldn't drive far. it would likely do it more often than just high gears as well. the stater could be loose or something but its main purpose is to flow fluid, you would rev but not go anywere. if your vibration increases with speed then i might think drive shafts. it could have a slight bend in it u wouldn't really notice unless it was really bent. i have broken many trannys and t-cases.
u do have a pretty thick chain in the t-case but it can stretch enough to make noises and is often mistaken for tranny problems.
u also say that you don't have the truck right now, so, unless its your wife driving, you don't really know how is being driven.
hope i'm helpfull
don't forget to check the pressure and wear pattern on those tires
boman47k 05-03-2010 02:32 PM
The vibration only seems to last during the shift. Truck drives good, no slipping, no odors,etc..
The reason I don't have it right now is I let my son take home with him about 70 miles away. This a former city utility meter reader truck.
