97 Astro Awd Pulls Agressively To The Left?? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-16-2010, 11:28 AM   #1
cowboy dan's Avatar
97 astro awd pulls agressively to the left??
before i get into the problem i just want to say, school is always in session, even if you are a mechanic.
to make a long story... longer:
when you hit the brakes at any speed the van dives to the left. the harder you hit the brakes the worse it is. if you ride the brakes just enough to trip the lights, so that the weight transfer is neutral and then hit the brakes, it doesn't pull at all.
but just read on
to date i have preformed the following services/parts:
carfax:
no history found.
brakes:
new brake rotors/calipers/pads/shoes/cyliders/linesx4sections/hydro booster/master/system flush x 2 trust me no little air bubbles and perfect peddle pressure/ service to abs mod: nothing found.
suspension:
torque bars inspected and leafs found to be weak. added leafs x2 , replaced ubolts/ shocks x4w/leveling overloads/ one new shock has seepage- front driver.
steering:
wheel bearings inspected: passed. replaced pump/idler arms/pitman arm/tierods inners/outers/adjusters/drag link/ balljoints x4 /cv axles.
tires:
new bfg 235/60/15 and capped with a 4 wheel alignment/ 120 point inspection, revealing that i have alot on new parts.
unibody:
inspected at frame shop... nothing found.
to date... still has the same problem.
stumped:
2 dealerships/ 2 local shops/one performance shop
the way i see it, is, either i missed something or i need to go back around the block starting with the suspension.
thanks to anyone who has a new and fresh idea.
cowboy dan is offline   Reply With Quote
Old 06-16-2010, 01:59 PM   #2
Here's a start
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Using the advanced search option you can subtract words you don't want, corresponding to what has already been tried.
I guess I'd search for whatever is left, if there is anything left.
The Following User Says Thank You to Yoyizit For This Useful Post:
cowboy dan (06-16-2010)
Old 06-17-2010, 06:43 AM   #3
47_47's Avatar
Rewards Points: 58
Did you drive it with a Tech II, monitor the wheel speeds to isolate the wheel?
47_47 is online now   Reply With Quote
Old 06-19-2010, 02:23 AM   #4
Rewards Points: 410
Sounds like sitcky caliper pins , did you thoroughly cleen them and reapply high temp greae.
High Gear is offline   Reply With Quote
Old 06-19-2010, 05:03 AM   #5
Rewards Points: 392
seems like the only thing left to try is the front rubber brake hoses. They break down internally sometimes and can restrict flow to a caliper. I've also experienced where it'll make a caliper piston unable to retract, too; acting as a check valve.
rustyjames is offline   Reply With Quote
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 8 01-14-2011 12:42 PM
cutting bevels left and right willitsian Carpentry 2 05-06-2010 04:59 AM
Rule of thumb...knobs or pulls and placement? Kelly R. Remodeling 4 02-11-2009 04:50 PM
How Many Years Left SirDieAlot Roofing/Siding 13 05-31-2008 02:11 PM
