96jeep Cherokee Wont Start - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-09-2009, 08:15 PM   #1
Question
96jeep cherokee wont start
ive been having problems with my truck not starting then as soon as i put in gear it dies so i have put a new coil a new thermostat and distributor cap and rotar button on it along with a new battery and now the thing will not start all together its got fire just not starting my fuel pump is kicking on and my filter is flowin it had a crappy little battery that kept getting drained so changed it now it wont start so is it a sensor or a vaccum leak or alternator
camdamron is offline   Reply With Quote
Old 07-09-2009, 08:48 PM   #2
Rewards Points: 150
Any codes? I would check fuel pressure also.
Gary
Gary_602z is offline   Reply With Quote
Old 07-09-2009, 09:08 PM   #3
how do i check fuel pressure and theres no codes bc the check engine light hasnt been on every time ive had it at the shop so they say that theres no way to check it if theres no check gauges light on which is crap i think but ive already spent a thousand dollars on the thing and now im left with doing this tryin to find out anything i can
Old 07-14-2009, 02:57 PM   #4
General Contractor
I would try pulling codes on it. Even if the check engine light is not on the computer may be storing codes. I would also check and make sure the light comes on when you turn the key to the on position. The bulb may be burned out. You said you have spark but you did not say if the engine was trying to turn over or is just the starter engaging. It could be something as simple as a broken wire or water in the fuel or: it could be a vacume leak, could be low cylinder compression, could be a bad MAF censor, could be bad or improperly gaped plugs, etc. If you are going to try to figure it out on your own get a Haynes or Chilton's manual on it if you have not all ready done so, then go through the troubleshooting section. I feel for you I've been there and know it can be frustrating but keep at it and you'll figure it out sooner or later.
ARI001 is offline   Reply With Quote
Old 07-15-2009, 10:12 AM   #5
I've had Jeeps for years and they can sure be a mystery sometimes. When's the last time you replaced the plugs? I'm assuming it's automatic?
I've found this site has some Jeep specific help:
http://www.jeepsunlimited.com/forums/index.php
Sean
sgo70 is offline   Reply With Quote
Old 07-15-2009, 11:16 AM   #6
BIGRED
Rewards Points: 252
It could be something simple like a broken, or burned coil wire too. I used to run plug wires so long that they would dry out, burn through, and start cross-firing and firing to ground. I stopped being penny frugal one winter during a snow storm when the engine was bucking and spitting and I opened the hood and saw the most brilliant lightening show you ever saw flashing all over the engine compartment.
Grampa Bud is offline   Reply With Quote
96 Jeep Grand Cherokee won't start ocoee Automotive Repairs 14 06-08-2009 10:44 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 12:39 PM
Mower won't start, anything I can try before bringing it to the shop? joeyboy Landscaping & Lawn Care 6 08-05-2008 03:08 PM
