96 Oldsmobile Brevada Running Rough - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-18-2013, 12:57 PM   #1
96 oldsmobile brevada running rough
I changed the fuel filter mass air flow sensor plugs wires still under a load wants to die what do y'all think maybe fuel pump weak ???
jra mechanics is offline   Reply With Quote
Old 12-18-2013, 02:59 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 936
Fuel pumps don't normally go halfway bad. They go or they don't.
Have you check the TPS voltage?
Old 12-18-2013, 03:52 PM   #3
Thanks for the advice I checked all the sensors in my data stream on my computer there all where there supposed to be I've worked on vehicles before that the pump was pumping weak from either hole in pick up tube etc that's the way it's acting but still not sure any other opinions please share thanks
Old 12-18-2013, 11:08 PM   #4
Rewards Points: 168
what do you mean by "under load" ?
does it drive ok, but idle crappy ? if so, the egr has some crap stuck in it.
Fix'n it is offline   Reply With Quote
Old 12-19-2013, 08:50 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,.... What's the fuel Pressure,..??
Bondo is online now   Reply With Quote
Old 12-19-2013, 11:01 AM   #6
Remodeler
Rewards Points: 302
Gm vehicles with the vortec engines require around 60 psi fuel pressure. A drop into the 50psi range may not even be enough to get the engine started, let alone allow it to run smoothly. Low fuel pressure issues are not uncommon with these engines.
The first thing to check would be fuel pressure, sounds like you may have a weak pump or a problem with the fuel pressure regulator.
iamrfixit is offline   Reply With Quote
Old 12-19-2013, 04:48 PM   #7
Rewards Points: 936
All good feedback so far.
Check:
TPS voltage
EGR cleanliness and function
Fuel Pressure
Old 12-19-2013, 05:42 PM   #8
Thank you all for your posts
Old 12-19-2013, 11:14 PM   #9
Lord of Slums
Rewards Points: 1,974
under load can also point to ignition system. What color is the spark? Under load at all speeds? Up hill? your cat blocked? Fuel pumps can develop strange problem that can last for years.
mj12 is offline   Reply With Quote
Rough Cost Estimate for Running a Dedicated 20A to Bathroom BayIslandMike Electrical 15 03-18-2013 03:53 PM
Help!! Sump pump won't stop running! kukubura Plumbing 25 11-02-2012 10:06 AM
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 05:00 AM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 01:45 PM
