-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   96 dodge grand caravan fluid leak (http://www.diychatroom.com/f46/96-dodge-grand-caravan-fluid-leak-115444/)
donniefarmer 08-27-2011 04:24 PM
Had tranny rebuilt last year and had no problems until I had to replace the power steering unit. Had to pull CV joint to get old out and new in. Replaced seal when putting back together but not fluid is just leaking out as fast as I put it in. HELP!
ukrkoz 08-27-2011 07:25 PM
1. you broke the seal reinstalling driveaxle
2. you did not seat seal in right
3. all of the above.
unlikely, but you may have mismatched seal and driveaxle input shaft.
PS. you did not put driveaxle back in all the way. Happens. been there.
Marty1Mc 08-28-2011 11:49 AM
My vote is "PS." OP, the axle needs a bit of force to seat it into the transmission. Make sure the splines are lined up, the with some force it will pop in. There is a metal ring around the end of the shaft about an inch in. That ring needs to compress and then the shaft will slide into place. It takes a bit of force to get it to go.
ukrkoz 08-28-2011 06:10 PM
marty's right, some drivexales must be sledge hammered into transmission to set right. Your clue will be an audible click, when spring ring locks in place. all driveaxles have a special mating surface to seal against the seal, it's turned on input shaft at 45 degrees. must sit flush against seal, or bust.
