95 Taurus Electrical Fire - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-27-2013, 05:17 PM   #1
Bigplanz's Avatar
Rewards Points: 996
95 Taurus electrical fire
95 Taurus and the battery was dead. I got a new battery and started to put it in. First thing I should have noticed as wrong was sparking at the negative terminal when I connected it. Before I even tightened the termnal, smoke, then flames in the wiring up by the firewall, between the shock tower (passenger side) and fire wall.
Very exciting! After oh shhhht I jerked off the negative cable and the flames were gone. A wire in the harness was burned completely through.
Anybody have any insights on the cause of this dead short? Key was not in the ignition, just replacing a dead battery. Thanks.
Bigplanz is offline   Reply With Quote
Old 03-27-2013, 05:38 PM   #2
Was it a large wire or a small wire?
And was the wire a do-it-yourself add-on wire without a fuse?
Billy_Bob is offline   Reply With Quote
Old 03-27-2013, 06:04 PM   #3
Bigplanz's Avatar
Rewards Points: 996
Small wire, part of the wiring harness that runs back there. Should have been protected by a fuse. Smoke, flames, o shhhht!! Whoa!
Oh, and I am, well, positive that the positive cable was connected to the + terminal and the negative cable was connected to the - terminal on the battery.
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 08:52 PM
breaker panel positioning regulations orobono Electrical 1 10-27-2012 03:25 PM
electrical panel fire rating Dean Killmer Electrical 0 07-12-2011 12:53 PM
Emergency Time Sensitive Post: Electrical fire qustion mahjohn Electrical 7 08-11-2008 05:37 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
