Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-15-2010, 10:22 PM   #1
'95 T-Bird: How to remove exterior door trim strips?
'95 T-Bird has exterior trim strips on the doors and they continue on to the body behind the door.
They are corroded and I want to re-finish them. How do they come off?
Can you remove them from outside the car? are they fastened with a clip? or
Do you have to take the door lining off and interior trim and detach them from inside the car?
Thanks, John aka JayKay
JayKay is offline   Reply With Quote
Old 03-16-2010, 07:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... I would imagine they're Glued on...
Old 04-14-2010, 01:06 PM   #3
cowboy dan's Avatar
yes. gm uses 3 common types. glue, double sided sticky tape, and clips. the clips are stuck to the body and the moulding is mounted to the clips. they won't be your standard clips though, gm likes to mix it up a bit by using barbed metal to plastic cleet. have fun and take your time
i might invest in a panel popper
cowboy dan is offline   Reply With Quote
Old 04-15-2010, 10:11 AM   #4
I also posted this on a couple of Ford Forums and received zero replies which is disappointing as some of those forums have moderators who are very knowlegable and I can't believe that no-one knows the answer to this.
Anyway, please forgive the rant and I really appreciate your response. I believe these are clipped on and as you say, it's difficult to figure out what type of clips they used. The car has pearl white paint in nice condition. My experience with exterior trim clips is that you usually end up damaging something in order to find out how the clips work. I will just work one patiently in good light from the bottom. Once I have one figured out the rest are easy.
For what it's worth, I'm going to paint the strips a contrasting color, probably blue probably metallic fading from darker to lighter at the edges.
I have done this with other cars with good results, cheap customization and if you mess up or don't like it or even get sick of it, you can fix or change it very easily.
John aka JayKay
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Bird Block Soffit replacement options? Heather WA Roofing 4 02-25-2011 11:06 AM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General Discussion 8 05-11-2009 08:09 PM
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 06:51 PM
