95 Dodge Dakoda, Need Part Identification - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-09-2010, 08:40 AM   #1
Rewards Points: 150
95 dodge dakoda, need part identification
Very low heat inside cab, and vacuum from hand pump was lost at what I believe to be a cruise control of some sort (cruise control inside not working) capped off vacuum line and heat returned inside. With hood up looking at the firewall left side up high, its a part with wires going to it ,extreme left unit. Checked Napa for a cruse control unit and no listing. What do I ask for? .....Bernie
bernieb is offline   Reply With Quote
Old 12-09-2010, 08:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Checked Napa
Ayuh,... Check with Dodge,... It's probably a Dealer Only part that Napa don't carry...
Old 12-09-2010, 10:34 AM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
probably has nothing to do with your heat, but if your cruise control isn't working you might want to look into the dodge clock spring recall and see if your truck is covered by this
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-09-2010, 12:04 PM   #4
Rewards Points: 150
The lady at the Dodge parts department, said its the "servo" and requires a wiring kit 96 bucks plus 35 for the wiring kit ..........will try the salvage yard ,and thanks for the comeback.
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 07:43 PM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 09:48 AM
Part Identification tomoni82 Landscaping & Lawn Care 4 07-25-2010 03:36 PM
How to get a level floor out of one that's part concrete and part wood Songbird Flooring 5 01-23-2009 12:24 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 10:31 AM
