-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   95 dodge dakoda, need part identification (http://www.diychatroom.com/f46/95-dodge-dakoda-need-part-identification-89140/)
bernieb 12-09-2010 08:40 AM
Very low heat inside cab, and vacuum from hand pump was lost at what I believe to be a cruise control of some sort (cruise control inside not working) capped off vacuum line and heat returned inside. With hood up looking at the firewall left side up high, its a part with wires going to it ,extreme left unit. Checked Napa for a cruse control unit and no listing. What do I ask for? .....Bernie
Bondo 12-09-2010 08:48 AM
Checked Napa
Ayuh,... Check with Dodge,... It's probably a Dealer Only part that Napa don't carry...
Mr Chips 12-09-2010 10:34 AM
probably has nothing to do with your heat, but if your cruise control isn't working you might want to look into the dodge clock spring recall and see if your truck is covered by this
bernieb 12-09-2010 12:04 PM
The lady at the Dodge parts department, said its the "servo" and requires a wiring kit 96 bucks plus 35 for the wiring kit ..........will try the salvage yard ,and thanks for the comeback.
