94 Ford Explorer A/c Clutch Replacement - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-05-2008, 10:42 PM   #1
Question
94 ford explorer a/c clutch replacement
Any tips on checking the compressor for leaks before the new clutch is installed. I have no special hivac tools except a a/c gauge set and a tank of 134a. The clutch is noisy, sparks, and smokes if ac is turned on. It seems to be cold. Thanks cb
explorer is offline   Reply With Quote
Old 09-06-2008, 03:18 AM   #2
Oldguy
Rehabber's Avatar
If the clutch is noisy engaged, more than likely the compressor is going bad and starting to lock up. It's prolly time for a compressor
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
94 Ford explorer air conditioning johntherault Automotive Repairs 5 04-17-2008 09:32 AM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 11:02 AM
2005 Ford Explorer Mystery Bell panhandlion Automotive Repairs 6 03-19-2008 09:27 PM
