93 Ford Ranger A/C Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-14-2010, 03:38 PM   #1
Question
93 Ford Ranger A/C problem
1993 Ford Ranger XLT 4x4 , 3.0 V6
the clutch on the A/C compressor keeps kicking in and out even when the A/C is not on. when it engages it puts enough load on the motor to affect the RPMs.
what would cause this? is the compressor shot? or is it maybe some problem electricly? i unpluged the wiring to the compressor and the problem stopped.
any thoughts??
thanks
robcourtis is offline   Reply With Quote
Old 06-14-2010, 09:20 PM   #2
Air conditioner compressor should be on when defrost is on. This is to help clear windows. If the compressor is on constant or intermittant, regardless of where the control is set, you most likely have an electrical problem.
Giles is offline   Reply With Quote
Tags
1993 , a/c , ford , ranger
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 08:19 AM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 12:24 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
