92 Firebird Curise Control - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-09-2009, 06:08 PM   #1
An old Tradesmen
Rewards Points: 6,886
92 Firebird curise control
I've been getting rid of this car for years now. But, it runs good except for the cruise control not working. So I keep it for a run around car.
I would like to get the cruise control working.
Have no idea what to check first, or what is a common failure on them.
Anybody know, or have a good starting point.
Old 12-10-2009, 11:13 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,... The Fuse maybe,..??
Old 12-10-2009, 11:26 AM   #3
An old Tradesmen
I did check that, and found no blown fuses.
Old 12-12-2009, 01:41 PM   #4
ask me how I know
where to start
Beenthere,
Cruise can be simple or complex problem. If I remember right the cruise on that vehicle is in the turn signal switch. These switches are easy to change but really dont offer much in the line of testing. Here are a couple of things to try. First turn the cruise on and drive over 30 mph and take your toe and lift UP on the brake pedal, and thenn try to set the cruise. If that works adjust or replace your brake light switch. Also check to see if your brake lights are working, that may be an indicator. If that does not work try setting the cruise with the "RESUME" button. That will usually work if the switch is failing.
groutonce
groutonce is offline   Reply With Quote
Old 12-12-2009, 05:41 PM   #5
An old Tradesmen
Thanks, I'll try that tomorrow.
Old 12-13-2009, 10:30 AM   #6
Post a close-up photo of the cruise control ckt bd.
If the thing doesn't draw any current you have a chance of being able to fix this thing.
Inifinity Control and Dual Fuel n2001nhl HVAC 1 10-03-2009 12:34 PM
Using a thermostat/relay to control baseboard heater perpetual98 Electrical 10 06-07-2009 11:57 PM
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
control 4 switches gooch Electrical 3 01-03-2008 08:05 PM
