90 Chevy Blazer - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-25-2009, 08:31 AM   #1
Post
90 chevy blazer
the tire on the driver's side lean out and is not straight. what causes this?
darney is offline   Reply With Quote
Old 06-25-2009, 09:29 AM   #2
47_47's Avatar
Rewards Points: 50
Improper front end alignment, worn or bent steering parts, bent frame, broken spring.... Need to check the front end parts.
Added: How far does the left front tire lean out? Usually the left front has more camber (lean out) to compensate for the road crown.
47_47 is offline   Reply With Quote
Old 06-25-2009, 10:42 AM   #3
Oldguy
Rehabber's Avatar
Camber should be the same on both sides since the advent of radial tires. The Caster angle is changed to make up for road crown.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-25-2009, 11:56 AM   #4
47_47's Avatar
Rewards Points: 50
You are right Rehabber, for this vehicle where caster, camber and toe are adjustable. Setting caster slightly higher on the right is used to compensate for road crown.
My additional comments about camber were directed to the majority of cars with MacPherson strut and rack and pinion steering. Front caster is non adjustable on most vehicles from the factory. This leaves the camber adjustment to compenstate for the crown.
Old 07-23-2009, 10:34 PM   #5
On this vehicle only the toe is adjustable.
Camber and Caster are not adjustable.
oregondiy is offline   Reply With Quote
Transmission chevy motor automatic sharlani Automotive Repairs 6 07-23-2009 10:39 PM
Chevy Tracker O2 sensor. Need help! sv9779 Automotive Repairs 9 03-02-2009 05:44 PM
'68 Chevy P/U Conversion to FI/700R4? o_jay66 Automotive Repairs 10 02-10-2009 06:46 PM
2004 S10 Blazer gas tank joeyuk Automotive Repairs 5 06-13-2008 09:41 AM
