-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   90 chevy blazer (http://www.diychatroom.com/f46/90-chevy-blazer-47445/)
darney 06-25-2009 08:31 AM
90 chevy blazer
the tire on the driver's side lean out and is not straight. what causes this?
47_47 06-25-2009 09:29 AM
Improper front end alignment, worn or bent steering parts, bent frame, broken spring.... Need to check the front end parts.
Added: How far does the left front tire lean out? Usually the left front has more camber (lean out) to compensate for the road crown.
Rehabber 06-25-2009 10:42 AM
Camber should be the same on both sides since the advent of radial tires. The Caster angle is changed to make up for road crown.:yes:
47_47 06-25-2009 11:56 AM
You are right Rehabber, for this vehicle where caster, camber and toe are adjustable. Setting caster slightly higher on the right is used to compensate for road crown.
My additional comments about camber were directed to the majority of cars with MacPherson strut and rack and pinion steering. Front caster is non adjustable on most vehicles from the factory. This leaves the camber adjustment to compenstate for the crown.
oregondiy 07-23-2009 10:34 PM
On this vehicle only the toe is adjustable.
Camber and Caster are not adjustable.
