Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-22-2011, 06:33 PM   #1
tonystewart1's Avatar
88 subaru justy
I have an 88 subaru justy 4wd but the rear differential wont lock in.
Does the vacume line connect to the rear differential?
If it does, then I need to run a new vacume line.
We found a conncetion near the vacume switch but when 4wd button is pressed it quits sucking and it sucks when 4wd drive button is disengaged.
You can hear the switch click when the 4wd button is pressed.
Is this the right conncection for the vacume hose to connect to?
tonystewart1 is offline   Reply With Quote
Old 08-24-2011, 06:15 AM   #2
Jack of All Trades
88 subaru justy
I haven't a clue as to an answer for you, it does sound counter-intuitive though, you'd think that the switch would apply vacuum when activated not remove it. Just in case you don't get an answer here, try these guys too: http://www.ultimatesubaru.org I got loads of answers back when I had my '85 GL.
DoctorWho is offline   Reply With Quote
Subaru product numbers boman47k Automotive Repairs 0 03-26-2011 11:18 PM
error on Subaru milleage meter MikeDuff Electrical 1 02-21-2011 08:42 PM
Subaru Outback Rear Wiper Arm Jazan Automotive Repairs 5 01-17-2011 09:34 PM
Help! Subaru Outback differential question grittypretty Automotive Repairs 3 02-11-2010 04:47 PM
2002 subaru, no power osdhero Automotive Repairs 2 06-25-2009 11:14 PM
