-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   88 subaru justy (http://www.diychatroom.com/f46/88-subaru-justy-114911/)
tonystewart1 08-22-2011 05:33 PM
88 subaru justy
I have an 88 subaru justy 4wd but the rear differential wont lock in.
Does the vacume line connect to the rear differential?
If it does, then I need to run a new vacume line.
We found a conncetion near the vacume switch but when 4wd button is pressed it quits sucking and it sucks when 4wd drive button is disengaged.
You can hear the switch click when the 4wd button is pressed.
Is this the right conncection for the vacume hose to connect to?
DoctorWho 08-24-2011 05:15 AM
I haven't a clue as to an answer for you, it does sound counter-intuitive though, you'd think that the switch would apply vacuum when activated not remove it. Just in case you don't get an answer here, try these guys too: http://www.ultimatesubaru.org I got loads of answers back when I had my '85 GL.
