85 Nissan Pickup Electrical Problems - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-15-2011, 02:22 PM   #1
kwikfishron's Avatar
Rewards Points: 180
I just picked up an 85 Nissan PU the other day and have no turn signals, brake or running lights.
The fuses under the drivers compartment are good and there is power to the fuses. What should I be checking next?
Is there another fuse box somewhere? If there is I’m not seeing it.
kwikfishron is online now   Reply With Quote
Old 08-15-2011, 03:54 PM   #2
Rewards Points: 180
A new piece to the puzzle.
I just looked over and the running/brake lights were on. The switch is off and the key is off. I had to pull the fuse to get them to go off.
Old 08-15-2011, 04:43 PM   #3
Rewards Points: 52
Does it have a trailer wiring harness? Even if not, it probably has a plug for one, someplace near the rear of the vehicle, tucked up in the frame somehow, which could be corroded. I can't speak specifically to your '85 Nissan, but, in general, that is the first place that I would go.
Old 08-15-2011, 04:48 PM   #4
Experienced
Jackofall1's Avatar
Did they have those kind of options on vehicles that long ago.....
Sounds to me like moisture on or in the fuse block.
Mark
Old 08-15-2011, 05:26 PM   #5
Rewards Points: 180
There’s no harness and all appears to be tight under the bed, no signs of corrosion.
Same with the fuse box, no signs of moister, all clean and shiny.
Old 08-15-2011, 05:45 PM   #6
A Little Of Everything
Rewards Points: 1,364
Several months ago I picked up an old "project" Volvo that had been in storage for quite awhile. It has had all kinds of weird little electrical gremlins, most of which are related to non-use.
The problem you're facing is that there's no one right answer to these problems. It could be a broken or cut wire, a bad brake light switch, dirty or corroded contacts, etc.
Hate to say it, but you're probably going to have to just go through the thing - electrical circuit tester in hand - and figure it out piece by piece.
DrHicks is offline   Reply With Quote
Old 08-15-2011, 10:29 PM   #7
NACE Coating Inspector
mustangmike3789's Avatar
i had the same thing happen in my 92 nissan. it was a small black box that looks like a relay under the dash just to the right of the steering column. i forget what the part was called but i bypassed it after it cooked a bunch of wires inside of the dash. i just ran every thing the old way with swiches and relays.
mustangmike3789 is offline   Reply With Quote
Old 08-15-2011, 11:12 PM   #8
Rewards Points: 252
Must be something about 92 Maximas. I fixed a running/brake light issue where the socket melted in the rear, shorted and caused the lights to be on constantly.
Marty1Mc is offline   Reply With Quote
Old 08-17-2011, 02:52 PM   #9
Rewards Points: 180
That’s exactly what it was. The truck has just sat outside and not being driven for the last 5 years or so.
I bumped the signal switch and things started to work again (for a minute anyway). I opened up the column to access the switch, sprayed some cleaner in there, worked the switch for awhile and she came back to life. Same thing with the brake switch.
Electrical Brainstorming Dragonfly Electrical 14 05-14-2010 03:37 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 11:49 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
