-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   85 Nissan Pickup Electrical Problems (http://www.diychatroom.com/f46/85-nissan-pickup-electrical-problems-114119/)
kwikfishron 08-15-2011 01:22 PM
199 Attachment(s)
I just picked up an 85 Nissan PU the other day and have no turn signals, brake or running lights.
The fuses under the drivers compartment are good and there is power to the fuses. What should I be checking next?
Is there another fuse box somewhere? If there is I’m not seeing it.
kwikfishron 08-15-2011 02:54 PM
199 Attachment(s)
A new piece to the puzzle.
I just looked over and the running/brake lights were on. The switch is off and the key is off. I had to pull the fuse to get them to go off.
DexterII 08-15-2011 03:43 PM
Does it have a trailer wiring harness? Even if not, it probably has a plug for one, someplace near the rear of the vehicle, tucked up in the frame somehow, which could be corroded. I can't speak specifically to your '85 Nissan, but, in general, that is the first place that I would go.
Jackofall1 08-15-2011 03:48 PM
Did they have those kind of options on vehicles that long ago.....:eek:
Sounds to me like moisture on or in the fuse block.
Mark
kwikfishron 08-15-2011 04:26 PM
199 Attachment(s)
There’s no harness and all appears to be tight under the bed, no signs of corrosion.
Same with the fuse box, no signs of moister, all clean and shiny.
DrHicks 08-15-2011 04:45 PM
Several months ago I picked up an old "project" Volvo that had been in storage for quite awhile. It has had all kinds of weird little electrical gremlins, most of which are related to non-use.
The problem you're facing is that there's no one right answer to these problems. It could be a broken or cut wire, a bad brake light switch, dirty or corroded contacts, etc.
Hate to say it, but you're probably going to have to just go through the thing - electrical circuit tester in hand - and figure it out piece by piece.
mustangmike3789 08-15-2011 09:29 PM
i had the same thing happen in my 92 nissan. it was a small black box that looks like a relay under the dash just to the right of the steering column. i forget what the part was called but i bypassed it after it cooked a bunch of wires inside of the dash. i just ran every thing the old way with swiches and relays.
Marty1Mc 08-15-2011 10:12 PM
Must be something about 92 Maximas. I fixed a running/brake light issue where the socket melted in the rear, shorted and caused the lights to be on constantly.
kwikfishron 08-17-2011 01:52 PM
199 Attachment(s)
That’s exactly what it was. The truck has just sat outside and not being driven for the last 5 years or so.
I bumped the signal switch and things started to work again (for a minute anyway). I opened up the column to access the switch, sprayed some cleaner in there, worked the switch for awhile and she came back to life. Same thing with the brake switch.
