77 Ford Ex; Manifold Leaking, My Dads Truck. - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-02-2010, 04:58 PM   #1
bsa_bob
Rewards Points: 150
Question
77 ford ex; manifold leaking, my dads truck.
I haven't done one in a long period of time.Should i soak.or heat up the manifolds good before tryin to get the bolts out??? I f you have a better idea....please share it with me.my dads gone now,and i promised him i'd take care of his old truck, he bought it new and left it with me, thanks for any help bob s
bsa_bob is offline   Reply With Quote
Old 11-02-2010, 05:26 PM   #2
Soy Candle Depot
As far as removing the rusty old bolts, I've found that Gibbs Brand lubricant works awesome. I use it for so much more than just rust bolts. Soak them every day for a few days if you're not in a hurry. When you're ready to take them off, hopefully they will come out, but if not, add some heat with a torch.
SoyCandleDepot is offline   Reply With Quote
Old 11-02-2010, 06:06 PM   #3
bsa_bob
Rewards Points: 150
Question
thanks for the repy sir, Can you heat the bolt with out it twisting off? or should i heat the head up next to the bolt?????
And where did you find"gibbs lubricant"??? i've not heard of this before? bob s
Old 11-02-2010, 06:33 PM   #4
Soy Candle Depot
Ideally you'll want to avoid head but you can use it as a last resort. Heat can warp or damage the head and the gasket sealing surface.
I learned about Gibbs on the "Powerblock" on sunday mornings on spike TV. They have all kinds of great products and tips on there. The stuff really is great and I use it all over the house. It is by far the best penetrating oil I've ever used. It works its way into everything!
Truck ants Thurman Pest Control 17 08-29-2010 08:50 AM
50amp GFI Trips on Commercial Truck djeffwhite Electrical 1 03-10-2008 02:04 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
