'71 Volvo Rough Idle - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-19-2013, 02:07 PM   #1
Rewards Points: 260
'71 Volvo rough idle
Hi all. I have a '71 Volvo 1800 that has a strange idling problem. When I first start it up, it idles fine, but then all of a sudden, around 30 seconds or so into idling, it drops down significantly. It's a 4 cylinder engine and 2 of the spark plugs have white tips, but all of the injectors are "squirting" appropriately. Does anyone have any idea why this might be happening? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 07-21-2013, 07:52 PM   #2
ukrkoz's Avatar
Rewards Points: 934
Go here:
http://www.rotaryeng.net/Spark-plugs/Spark-plugs.html
Scroll down to color chart, find your plugs, and read what it means.
Wanted to say - you run lean on those 2 plugs, ha-ha, indeed:
A clean, white insulator firing tip and/or excessive electrode erosion indicates this spark plug condition. k This is often caused by over advanced ignition, timing, poor engine cooling system efficiency (scale, stoppages, low level), a very lean air/fuel mixture, or a leaking intake manifold. When these conditions prevail, even a plug of the correct heat range will overheat.
Clean fuel injectors.
ukrkoz is offline   Reply With Quote
Old 08-21-2013, 09:17 PM   #3
Sounds like you have a vacuum leak. With the engine idling, spray mist of water around the engine area. The engine will start to die or run rough if the leaking area gets sprayed
msmith5554 is offline   Reply With Quote
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 02:50 PM
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 05:00 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Rough Lawnmower idle. Please advise. Shaun_in_NC Landscaping & Lawn Care 2 01-01-2009 05:44 PM
'79 Jeep CJ7 rough idle Jeeper1970 Automotive Repairs 13 12-20-2008 07:12 PM
