-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   2009 Montana Van tire warning (http://www.diychatroom.com/f46/2009-montana-van-tire-warning-88528/)
Wildie 12-03-2010 10:11 PM
I have a warning that my right front tire is low and needs to be serviced.
I checked the pressure with a tire guage and it is set to the correct pressure.
What is the next approach to resolving this problem?
I'm thinking of rotating the wheels (RF to LR, LF to RR) would this be a good way to ascertain whether I have a bad tire transmitter?
How does the computer know which tire is which?
rusty baker 12-03-2010 11:45 PM
Unhook the positive battery cable and then rehook. That may reset the computer if you have a glitch.
Scuba_Dave 12-03-2010 11:58 PM
I was told there is a sensor in each tire
Seems to be true according to Wiki
There is also a problem that causes false readings...forget what it was
Bondo 12-04-2010 07:55 AM
Ayuh,... I assume you have radial tires,...
They should be rotated on the same side of the vechicle...
Left front to left rear, right front to right rear...
Rehabber 12-04-2010 08:32 AM
:no:This has not been true for many years. Read your owners manual, check ANY tire manufacturers website, or RMA websites. This is another myth being perpetuated. :yes:
Wildie 12-04-2010 05:36 PM
I found an answer to my problem!
GM has a routine, where you hold the OPEN and LOCK buttons on the remote fob until the horn toots.
Then you release air pressure in the LF tire until the horn toots again. Do the same with RF tire, then the RR tire and finally the LR tire.
This is how the computer relates the transmitter to the computer.
Then, of course, the tires need to be re-inflated to the proper pressure.
Thanks for all your replies! :yes:
Thurman 12-04-2010 11:47 PM
"Wildie", this may be the re-programming method for your GM vehicle, but it is not the re-programming method for ALL of GM's vehicles. Just to let you know. I have an '07 GMC Sierra truck and this is totally different than my book states. Mine is so complicated to me that I just let my local tire/alignment shop (owned by a friend) do this with their computer. And YES, each tire has it's own sensor built into the valve stem unit. And--they are not cheap. Those for mine run about $115-$135 per tire depending on where you buy them. Not to sure if this is a good thing or not--Yet!
Wildie 12-05-2010 12:58 AM
Thanks for the info! I'm somewhat confused though, as I thought the webpage said GM rather than Montana. I'll look again and verify this!
Has GM simplified the routine on later models?
burnt03 12-05-2010 04:50 AM
What's not true, rotating front to back without going left to right? This was the recommended procedure on my old 03 Corolla (front to back only).
Thurman 12-05-2010 10:30 AM
A friend of mine owns a major, reputable tire/alignment shop here now in it's third generation of business/ownership. I do spend time there and often help with things. Today's radial tires CAN be "X" , or "cross rotated". The ideal rotation involves the spare tire also, if the vehicle has a full size spare. The main problem with that is most of today's vehicle's come with four aluminum wheels and the spar is on a steel rim. This necessitates having to swap two tires and rims to get the tires into proper rotation and people don't like to pay for the tire/rim swapping. So many used vehicles out there today with 100,000 miles on them and the original spare with the vehicle. So, on an '03 Toyota Corrolla, the owner's manual probably did state to rotate straight only. Life changes, procedures change each day now
polarzak 12-06-2010 06:44 AM
Rotation depends on the vehicle. It is no a myth to rotate front to back. Some vehicles suggest this method in the owner manual, some suggest the X pattern. It pays to read.
