2009 Chevy Malibu LTZ Squeaks - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-11-2013, 08:54 PM   #1
2009 Chevy Malibu LTZ squeaks
I just bought a 2009 Chevy Malibu LTZ last week from a dealer. It has under 65K on it. When I started it tonight, it seemed to make a squealing sound. After I revved it for a bit and cranked the heat, it seemed to go away...I didn't stay in the vehicle long enough to see if it completely went away.
What could this be and should I be worried about it?
Should I take it back to the dealer and get them to look at it? They put it through their "safety" process prior to me purchasing it.
kidicarius is offline   Reply With Quote
Old 11-11-2013, 09:00 PM   #2
ukrkoz's Avatar
Rewards Points: 946
water pump.
ukrkoz is offline   Reply With Quote
Old 11-12-2013, 04:56 AM   #3
Rewards Points: 13,468
I'd be taking a look at the timing belt to see if it looks like new.
It was suppose to be changed at 60,000 miles.
Old 11-12-2013, 06:18 AM   #4
Rewards Points: 1,294
If it is the 2.4L engine it has a timing chain, not a belt. Timing belts won't squeal anyway as they are cogged to stay in time. Posibly it is the accessory drive serpentine belt. right after startup the battery needs recharging so there is a heavy load on the alternator which could cause belt slippage on a worn belt. Serpentine belts usaully don't slip but it is not unheard of especialy if the tensioner is weak. Any unusuall noise from a car is something to be concerned about and should be checked out. If you are not able to diagnose this yourself then a qualified tech should look at it. Most likely, if it is a reputable dealer, they will take care of it for you
danpik is offline   Reply With Quote
The Following 2 Users Say Thank You to danpik For This Useful Post:
joecaption (11-12-2013), oh'mike (11-12-2013)
Old 11-12-2013, 06:35 AM   #5
That's the belt I meant, my bad.
Old 11-12-2013, 08:31 AM   #6
ukrkoz's Avatar
Rewards Points: 946
Well, let me circle back to this. I had a GM vehicle with exactly same noise - esp winter time - noise at cold start up slowly going away.
I had pulley replaced twice. But it still ended in water pump replacement. As it was water pump.
89 Chevy c3500 engine and wiring harness changeout thehvacguy Automotive Repairs 2 08-16-2013 09:19 PM
05 chevy malibu, brake not releasing 4just1don Automotive Repairs 9 10-22-2011 10:02 PM
What do you guys do to save on your Electricity bill? (2009 Edition) ehoez Electrical 47 04-10-2009 06:53 AM
Floor Squeaks JackOfAllTrades Flooring 6 01-22-2008 11:19 AM
Fixing squeaks where there's no joists wfischer Flooring 4 01-04-2008 09:35 AM
