2008 Lexus Rx350 Pull To The Right-WHAT PART? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-15-2015, 08:30 PM   #1
Rewards Points: 2
Exclamation
2008 lexus rx350 pull to the right-WHAT PART?
OK, i got a 2008 lexus rx350 that pulls to the right all of a sudden, no impact so im thinking part went through trouble shooting it and tires,cv shafts, ball joints, struts, control arms, excess grease or oil anywhere etc. all good. and it cant be alignment because it just went from normal to not, and the only thing i can see is a lower stabilizer bar link bushing on the drivers side has grease on it and looks bad all others are good. could this cause a sudden change in steering ex. alignment? with steering wheel straight wheels out about 25%ish. any thoughts or help would be greatly appriecated, leaving on a road trip on weds. and need to fix asap.
DAVINCI1 is offline   Reply With Quote
Old 03-15-2015, 08:47 PM   #2
Bigplanz's Avatar
Rewards Points: 534
Bad tire maybe? Sudden steering problems can result from a bad tire.
Bigplanz is offline   Reply With Quote
Old 03-15-2015, 09:19 PM   #3
ukrkoz's Avatar
Rewards Points: 630
Do you have electric steering assist? That can do it.
Otherwise, check control arm bushings and for loose wheel lug nuts.
ukrkoz is offline   Reply With Quote
Old 03-16-2015, 08:10 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 3,554
Ayuh,... Was all this testin', 'n checkin' done with the vehicle up in the air on jacks,..??
If not, you've checked, 'n tested nothin',....
'n what does That mean,..?? 25% of What,..??
Tags
alignment , steering , suspension , sway bar
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 12 04-13-2014 06:54 PM
Clicking sounds from unknown part between transformer and primary control Notsosuperman HVAC 7 03-07-2013 09:30 PM
No Pull lube jamiedolan Electrical 7 12-16-2008 12:00 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
