Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-25-2012, 07:05 PM   #1
2008 dodge caravan factory alarm - disable
Any way to disable it, or reset it? The van just starts honking at random times. Once while I was in a store and once when I was at work?
thoughts?
fjacky is offline   Reply With Quote
Old 01-25-2012, 09:29 PM   #2
Read the owner's manual (alarm part).
If that does not help, then you would need a Factory Electrical Diagrams manual and the Factory Service Manual set of books (order from dealer).
And understand the wiring diagrams.
Billy_Bob is offline   Reply With Quote
Old 01-26-2012, 07:26 PM   #3
In the manual it says
'Security System Manual Override'
The system will not arm if you lock the doors using the manual door lock plunger.
Hope that works.
Old 01-26-2012, 10:35 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rather than disabling the alarm, I'd spend time looking into why the alarm is going off. Check the door plungers and especially the hood plunger. If one of those get 'off' the car will think someone is opening the door or hood and sound the alarm. Common issue.
hyunelan2 is offline   Reply With Quote
96 dodge grand caravan fluid leak donniefarmer Automotive Repairs 3 08-28-2011 07:10 PM
2008 Grand Caravan fjacky Automotive Repairs 2 03-23-2011 12:42 PM
96 Dodge Caravan CV shaft? iceracer Automotive Repairs 10 11-18-2010 04:54 PM
1996 Dodge Caravan Overheating problem benlee Automotive Repairs 3 08-15-2009 11:27 PM
1995 Dodge Caravan "SHAKEIN" grumpypapa Automotive Repairs 3 02-18-2009 11:01 PM
