Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-03-2013, 10:11 AM   #1
2008 Chevy Impala CODE PO411
My Impala is reading Code PO411, Something to do with air intake. Is this maybe the air filter needs changed? Thanks
lemley98 is offline   Reply With Quote
Old 03-03-2013, 11:28 AM   #2
https://www.google.com/search?q=Code...hrome&ie=UTF-8
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 03-03-2013, 11:46 AM   #3
That is for the air injection system for emissions. You have a problem with the air pump or diverter valve. Check with a Chevy dealer may be covered on emissions warranty if you are under 80,000 miles
cjm94 is offline   Reply With Quote
Old 03-03-2013, 03:21 PM   #4
ukrkoz's Avatar
http://www.obd-codes.com/p0411
ukrkoz is offline   Reply With Quote
2008 NEC Code & AFCI Requirement theatretch85 Electrical 5 03-12-2009 10:58 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
NEC 2008 Code Cycle jamiedolan Electrical 19 10-05-2008 07:42 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
